0 It's Glamazon's Birthday!
0 First start question
Last Post: Jaime1840
0 Q cams in 73 xlh ??
Last Post: 73HEAD
0 "S" model specific Q&A
Last Post: Edster
5 How do I increase sag ?
0 HSR idle mixture screw
0 Track Bike Build
0 Pushrod hitting tube
Last Post: DR DICK
0 need help with 68 XLH
Last Post: DR DICK
0 Range With EFI 3.3 Gal Tank
Last Post: Mike1nw
Last Post: handa700
0 Gear and brake linkage
Last Post: Andy56
0 Oil pressure switch
0 Valve Stem Seal ID
Last Post: BruceM
  #321
Old 4th September 2019
Jason's Sporty's Avatar
Jason's Sporty Jason's Sporty is offline
Sportster/Buell Model: Sportster XLH 883/1207
Sportster/Buell Year: 1986
Sportster/Buell Year #2: 1972
Jason's Sporty has a reputation beyond reputeJason's Sporty has a reputation beyond reputeJason's Sporty has a reputation beyond reputeJason's Sporty has a reputation beyond reputeJason's Sporty has a reputation beyond reputeJason's Sporty has a reputation beyond reputeJason's Sporty has a reputation beyond reputeJason's Sporty has a reputation beyond reputeJason's Sporty has a reputation beyond reputeJason's Sporty has a reputation beyond reputeJason's Sporty has a reputation beyond repute
Here you go gofaster
Details on the front forks, and what was needed to get the OEM front rim to work with it please?
gofaster gofaster is offline
Sportster/Buell Model: XL883R
gofaster is an unknown quantity at this point
The piece that holds the axle and the radial mount Tokico brake caliper were custom designed and made by my son. Same with the triple trees. Fork tubes are GSXR (I think).
Old 5th September 2019
That is simply awesome. Any idea of the cost of making another set?
He made these back in 2003. I don't know if he still has the program, tooling,and fixtures to make more. I'll ask him when I see him and I'll let you know.
Old 20th October 2019
Jer Jer is offline
Sportster/Buell Year: 1991
Jer is an unknown quantity at this point
I hope it’s ok to post this here. This is my ‘91 1200 xlh I’ve been working on for a while now. My first attempt at completely customizing a bike.
Engine needed to be rebuild, as it was leaking between the crank case, which was the first time I’ve split cases. While the engine was out I decided to completely restyle the bike. Waiting on a bassani road rage in stainless I just ordered, and I still have quite a few little things to check off my list, but hoping to ride this year.
Here is what it looked like before I started..
Old 14th September 2021
99-883-c's Avatar
99-883-c 99-883-c is offline
Sportster/Buell Model: 99 883c sportster
Sportster/Buell Year: 99
99-883-c has a brilliant future99-883-c has a brilliant future99-883-c has a brilliant future99-883-c has a brilliant future99-883-c has a brilliant future99-883-c has a brilliant future99-883-c has a brilliant future99-883-c has a brilliant future99-883-c has a brilliant future99-883-c has a brilliant future99-883-c has a brilliant future
99 883 c
