Last Post: 73HEAD
Last Post: cazz1000
Last Post: Captain Johnny
Last Post: jcro61
0 Lurker from the SF Bay Area
Last Post: calileo
5 Rethinking 1250 Build
0 First start question
Last Post: MikeBel
0 Should I buy a Sportster??
0 Exhaust question
Last Post: Monte03
0 Bassani Baffle Supplier
0 Timing, static or strobe?
0 Starter Relay?
Last Post: xena
Last Post: Andy56
0 33.4mm fork bushings
0 help with stuck engine
doughboy (68), tinman (66), mofo (59), JAFI (58), Topgun (56), Hogwylde (56), Pay Toilet (55), grwhite038 (53), JWG883 (52), sorryifitburns (48), Leibniz (46), higgins14 (44)
883, carb, cv carb, tuning
Old 14th April 2011
rocketmangb's Avatar
Hey there RV7 !
first post and Welcome aboard !
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 14th April 2011
Rv7garage's Avatar
Rv7garage Rv7garage is offline
Sportster/Buell Model: 883R
Rv7garage has a reputation beyond reputeRv7garage has a reputation beyond reputeRv7garage has a reputation beyond reputeRv7garage has a reputation beyond reputeRv7garage has a reputation beyond reputeRv7garage has a reputation beyond reputeRv7garage has a reputation beyond reputeRv7garage has a reputation beyond reputeRv7garage has a reputation beyond reputeRv7garage has a reputation beyond reputeRv7garage has a reputation beyond repute
Hey gang thanks for the replys. So far we want to look at the accelerator pump- it works fine. Somebody mentioned idle speed- how do I know??! Without a tach I have no clue. I'll try upping the idle speed a bit and see what that does, and I'll also put a larger pilot jet in her while I'm at it.
Thanks again all. Funny but I posted this same question on the hd forums and got not one reply.
Old 14th April 2011
Rico 05R's Avatar
Rico 05R Rico 05R is offline
JESTER SYNDICATE
Originally Posted by Rv7garage View Post
...Thanks again all. Funny but I posted this same question on the hd forums and got not one reply.
Old 14th April 2011
seagullplayer's Avatar
seagullplayer seagullplayer is offline
seagullplayer is a splendid one to beholdseagullplayer is a splendid one to beholdseagullplayer is a splendid one to beholdseagullplayer is a splendid one to beholdseagullplayer is a splendid one to beholdseagullplayer is a splendid one to beholdseagullplayer is a splendid one to beholdseagullplayer is a splendid one to beholdseagullplayer is a splendid one to beholdseagullplayer is a splendid one to beholdseagullplayer is a splendid one to behold
Your bike is newer than mine, but I will tell you anyway.
The "barb fitting" where my gas line hooked to the carb was plastic, it was cracked and caused much the same problem as you describe. Yours will be brass, but a cracked fuel line between the tank and the carb could cause the same issue.
You loose very little gas, almost none when the engine is running (but it sucks air) and only what is in the short line when it is off, it can be hard to notice, smell more than anything else.
Worth a look perhaps.
There are a lot of nuts that carry a Bible, but not everyone that carries a Bible is a nut.
1995 883, Taxes paid, leaks a little oil, always needs cleaned, and could use a paint job, wanta race?
Old 14th April 2011
Durockrolly's Avatar
Durockrolly Durockrolly is offline
Other Motorcycle Model: GL1800
Durockrolly has a reputation beyond reputeDurockrolly has a reputation beyond reputeDurockrolly has a reputation beyond reputeDurockrolly has a reputation beyond reputeDurockrolly has a reputation beyond reputeDurockrolly has a reputation beyond reputeDurockrolly has a reputation beyond reputeDurockrolly has a reputation beyond reputeDurockrolly has a reputation beyond reputeDurockrolly has a reputation beyond reputeDurockrolly has a reputation beyond repute
Lets also make sure the accelerator pump is working !
Air filter off and twist the throttle and look for squirt down the middle of the carb throat.
Note !
Do this with the engine off if you value your eyebrows !
Yes! Many of us have learned this the hard way!!!
Been chatting to a 14 year old girl online. She's funny, sexy and flirty. Now she tells me she is an undercover cop! How cool is that at her age!?
Old 14th April 2011
02883r's Avatar
02883r 02883r is offline
Sportster/Buell Model: 883r
02883r is a name known to all02883r is a name known to all02883r is a name known to all02883r is a name known to all02883r is a name known to all02883r is a name known to all02883r is a name known to all02883r is a name known to all02883r is a name known to all02883r is a name known to all02883r is a name known to all
are your intake seals leaking where they mate to the heads? That can cause all sorts of low RPM problems. I'd check that first before digging into the carb. Take a spray bottle with water or can of WD40 and spray the seals while the engine is running. If the idle speeds up or the bike dies this is your culprit.
a side note..... DON'T use carb or break clean..... trust me......
Old 14th April 2011
Neck Whipped Neck Whipped is offline
Other Motorcycle Model: Suzuki Intruder 800
Neck Whipped is an unknown quantity at this point
I had a similar issue when I first got my bike. I found that there were a couple of things wrong. First I found that my accelerator pump was sticking. I had a nasty stumble so I took the carb off fixed that. Second, after I did my mods, I had to go to a larger slow jet. I had a 44 in and went to a 46 and shimmed the needle. No such problems since. 96 Hugger.
Old 14th April 2011
XLXR's Avatar
XLXR XLXR is offline
Rubbermount_EVO Carb basics and jetting by reading the plugs
This thread has a step by step method for jetting by reading the plugs at throttle positions related to the fuel circuits in the carb. It is hidden in one of the carb tuning sticky indexes. There are many other good stickies there also. Properly tuned carbs run great.
Old 9th April 2012
fishnfool's Avatar
fishnfool fishnfool is offline
fishnfool is an unknown quantity at this point
I'm glad you asked that question! My '97 883 does the same thing and it drives me crazy. With the number of guys trying to help you out...I'm bound to find the right one for me as well. I'm gonna go try a couple of them right now. Good luck with yours.
Old 9th April 2012
xena's Avatar
xena xena is offline
Assistant Administrator
Sportster/Buell Model: XL883 w Hammer 1275
Welcome to the forum! Hopefully the OP
got his issue resolved since he started
the thread one year ago.
After you've read some of the links
the guys posted, if you still have trouble
with the bike you might want to
start your own thread just for the sake
of being able to follow it a little better.
XLF Rules/Guidelines
XLF Guidelines II
Hammer Performance 1275 kit w flat tops, 2007 1200 heads with Hammer Impact Service, Hammer Performance custom billet intake manifold, Stock carb, N65C needle w 45/185 jets, K&N air cleaner, SE 497 Cams, Energy One clutch w 15% spring, Python 3 Slip ons, Dynatek DSPT-1 ignition on 28b
