Last Post: Fifty150
0 Off Road Lights
Last Post: Fifty150
Last Post: Hopper
0 Sportster S on the dyno
Last Post: crfblur
0 HSR idle mixture screw
0 First start question
Last Post: Fivecats
Last Post: Turbo Sporty 48
0 Should I buy a Sportster??
Last Post: riceburner
0 Front deflection
Last Post: denguy
Last Post: Fivecats
0 Ran out of gas.
Last Post: Hellbent_4
0 Best seat for long rides
Last Post: Diogenes415
0 need help with 68 XLH
0 2021 Iron Butt Rally
alternator, charging problem, generator, small battery
Old 10th October 2011
tongues101's Avatar
tongues101 tongues101 is offline
tongues101 is an unknown quantity at this point
Default Alternator vs generator on small battery
77 Sportster xlh with kick and electric start.
Electrics: Headlight, tail light, points and speedo.
Battery: ES12BS AGM (really small: 3 7/16 wide, 6 long, 5 1/8 tall, no extra space for bigger battery).
Bike has been totally rewired so there is no wiring or electrical issue.
Battery not charging. Replaced generator and CE regulator twice, and battery many times.
I think the gen. is boiling the battery!
Is there a gen. or alt. that will not boil this small style battery? Or any other advice.
ultra...good ultra...good is offline
ultra...good has disabled reputation
If you have replaced the gen and reg, and bat a few times and keep having issues, are you sure the wiring is good? Just because it is new...... I would disconnect the battery and run a few continuity tests to make sure your wiring is good. Just my thoughts though.......
tongues101's Avatar
I think the small battery is being boiled by the generator, but not sure how to check this!
I run a 7 amp hour battery on my XLCH, kick start only. A very small battery, and I do not have any issues with it being boiled over. The regulater is supposed to control how much power is generated or sent (not exactly sure) to the battery. If you have tried new generators, and new regulators and new batteries and still have issues, I would check the continuity of your wires to make sure you don't have a small short some where within your circuits. That might be sending a false signal from the battery to your regulator, or from the regulator to the generator, and causing it to keep charging your battery, making it boil over.
tongues101's Avatar
Thanks. Will investigate further. That's probably what's going on.
rivethog's Avatar
rivethog rivethog is offline
Sportster/Buell Year: '78
Sportster/Buell Model #2: 883 XLH
Sportster/Buell Year #2: 1993
Other Motorcycle Model: 93" Shovel/Pan
Other Motorcycle Year: 1967
rivethog has disabled reputation
Which CE regulator p/n did you replace? They make a low output regulator for small batteries.
ACE Hardware gr. 8 bolts Krylon & Rustoleum "premium" paint JT-6 waterproof grease, Emgo oil filter Loctite blue red & green AutoZone headlight bulb soxxet genuine Aftermarket rear fender generic countershaft sproxxet Radio Shaxx 16ga & 14ga wire forks off of a 180mph drag bike Swallow 4.60H18 rear tire 3.50 x 19 Shanghai front
Old 11th October 2011
you can use an inline dc amp meter or an inductive one to check it. the inline will be more accurate. this way, you can monitor the charge rate in amps. you can use a volt meter to watch the voltage. on startup, the amps will be higher and as the voltage comes up to charge level, the amps should drop. when the battery is charged, the system will operate off the generator or alternator and only take battery power when the cut in thresh hold is reached.
if this is a mechanical regulator, you might have to adjust the cut in and cut out settings, but if electronic, your hands are tied. make sure the regulator is sensing the battery and not a circuit with a load as the load in series will fool the regulator and it will try to bring the battery up. the battery should be ok with 14 to 15 volts but above that, the battery will suffer, ideally 14.2 volts is optimum. two failures seems to point to something ary in the wiring.
as for the electric foot, your battery might not have the cca and amp hours to fully satisfy its needs and will cause the battery to deep cycle. a lead acid battery does not like deep cycling and it will sulfate the plates. when this happens, the internal resistance rises and in order to bring the charge up, it will force more amps from the charging system which will cause battery heating and more damage.
racerwill's Avatar
Sportster/Buell Model: XLRR
Sportster/Buell Year: 91
Sportster/Buell Year #2: 80
the charging system doesn't care how big the battery is, as long as it's the correct voltage...... if the charging system is working correctly, running volts will be more than 13V and less than about 14.5V.....current (amps) will be higher when the battery is low and will go down to almost zero as the battery reaches fully charged.......check charging voltage (at about 2000RPM) if it's higher than 15 volts, the regulator is at fault......
Ww
master wizard
RIP Mr Jimi
"All The Way"
