0 The Beat Wife
0 Lurker from the SF Bay Area
5 Rethinking 1250 Build
Last Post: lehel
Last Post: mrmom9r
0 Electrical almost all sorted
Last Post: Andy Hog
0 So Long
Last Post: XL Ed
Last Post: xena
Last Post: skien
Last Post: 73HEAD
Last Post: cazz1000
Last Post: jcro61
0 First start question
Last Post: MikeBel
0 Should I buy a Sportster??
0 Exhaust question
Last Post: Monte03
0 Bassani Baffle Supplier
doughboy (68), tinman (66), mofo (59), JAFI (58), Topgun (56), Hogwylde (56), Pay Toilet (55), grwhite038 (53), JWG883 (52), sorryifitburns (48), Leibniz (46), higgins14 (44)
generator, regulator
Old 1st November 2012
Freelander03's Avatar
Freelander03 Freelander03 is offline
Sportster/Buell Model: XL 1000 75th Anniversary
Freelander03 is an unknown quantity at this point
Default Cheap Generator Source?
I've got a bad generator on my '78 Sporty... I recently replaced the battery, so I'd rather not have to do it again any time soon :-P
Ideally, I'd love to change to the Cycle Electronics Gen-Reg combo, but I just don't have $400 to shell-out right now. Actually, I don't really have $275 for a standard Gen either... I bought new brushes for $12 to see if I could refresh my existing Gen, but it didn't do the trick...
Does anyone know a cheap source for a replacement 12 Volt Gen?
brianbbs67's Avatar
Reformed Savant
Sportster/Buell Year: 1961
Sportster/Buell Year #2: 1970
Other Motorcycle Year: 1977
Man you can't go wrong with cycle electric. Save up its worth it. DGV-5000 got the built in regulator. Almost never looses polarity.
Folkie's Avatar
Folkie Folkie is offline
Brass Nut
Sportster/Buell Year: 2015
I'll move this to the Ironhead section, where you'll hopefully get the most replies.
Folkie
South East England Riders
hcrashster's Avatar
hcrashster hcrashster is offline
Sportster/Buell Model: XLH Spinegrinder
Sportster/Buell Model #2: XLCH Frankenstien
Sportster/Buell Year #2: 1976
Other Motorcycle Model: Triumph Groanyville
Other Motorcycle Year: 1972
hcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud of
E-Bay. Look for a used OEM and get a guarantee, if possible.
Failing that, save for the Cycle Electric. It will be the best money you will ever spend on your bike.
DO NOT buy a $100.00 China/ India POS, that are currently being sold every where. They are junk and will fail quickly.
Ordinarily he is insane, but he has his lucid moments when he is only stupid
fdny37's Avatar
fdny37 fdny37 is offline
Senior Master Bike Builder
Sportster/Buell Year #2: 1968
Other Motorcycle Year: 2014
Here is a Hitachi generator that I picked up on ebay NOS for $125 and I've seen more of them. These were used on the 1980's Sporties and Shovels and have more amps then the standard generators. Just as good as the Cycle Electric if not better, real heavy duty.
scottfisher's Avatar
scottfisher scottfisher is offline
Sportster/Buell Model: FLCH
Sportster/Buell Year: 61
Sportster/Buell Year #2: 60
scottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to behold
Read the sticky. fix your own equipt...learn how to do it once and you will be able to do it for life.
Sticky:
http://xlforum.net/forums/s....php?t=1085926
s
Scott
'61 'CH
'60 'CH
Hopper's Avatar
Hopper Hopper is offline
Other Motorcycle Year: 1942
The cheapest replacement generator is the Cycle Electric.
The others cost way more when the armature shaft snaps and falls down in among the cam gears. Has happened to many on here.
+1 on fix your old generator.
Most often they just need a $15 set of brushes and a clean up.
$20 worth of new bearings and it could be as good as new.
randy3934's Avatar
generator on an 80s shovel?
take it down to a place that can test it for you if you don't have the tools, you'll find out what's bad, armature, fields, since you put new brushes in, if they tell you it's alright then replace regulator.
How do you know it id bad? What tests have you done? Have you worked thru the Sticky? [especially steps 6 thru 12 but do all of them] ...
Ironhead Charging System Checkout
http://xlforum.net/forums/s...ad.php?t=39146
Pan55's Avatar
Pan55 Pan55 is offline
Sportster/Buell Year: 77
Sportster/Buell Model #2: XLH
Sportster/Buell Year #2: 77
Other Motorcycle Model: 1978 FX Shovelhead
Pan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to behold
check all your grounds...
polarize the gen..( jump from the *A* terminal on the gen, to the battery +.....one quick jump..)
ALSO..jump the regulator...
I fought an elec charging problem last year for about a month, went throught the generator, and from all testing it was working as supposed to...
new regulator, then even bought a new electronic regulator, still charging problems
( intermitant..sometimes good for a couple days then damn..dead battery..)
after making sure all the grounds were clean and solid ( motor mts etc...) I added a ground strap from the frame to the battery case, and one to the regulator mount... never had a problem again..
