0 The One Who Likes Pineapple
Last Post: Fifty150
Last Post: Fifty150
0 Off Road Lights
Last Post: Fifty150
Last Post: Hopper
0 Sportster S on the dyno
Last Post: crfblur
0 HSR idle mixture screw
0 First start question
Last Post: Fivecats
Last Post: Turbo Sporty 48
0 Should I buy a Sportster??
Last Post: riceburner
0 Front deflection
Last Post: denguy
Last Post: Fivecats
0 Ran out of gas.
Last Post: Hellbent_4
0 Best seat for long rides
Last Post: Diogenes415
0 need help with 68 XLH
0 2021 Iron Butt Rally
generator, regulator
Old 1st November 2012
shooterj2003 shooterj2003 is offline
shooterj2003 is a splendid one to beholdshooterj2003 is a splendid one to beholdshooterj2003 is a splendid one to beholdshooterj2003 is a splendid one to beholdshooterj2003 is a splendid one to beholdshooterj2003 is a splendid one to beholdshooterj2003 is a splendid one to beholdshooterj2003 is a splendid one to beholdshooterj2003 is a splendid one to beholdshooterj2003 is a splendid one to beholdshooterj2003 is a splendid one to behold
most of the time,if you take it to a reliable local electrics,guy ,he'll tell you what you need ,get it and put it in or even have him do it, it will be still cheaper than a new one,ask around at garages,whoever uses a guy the most ,thats your guy.I use a guy Ron's Auto electric,Near here in Bullville, N.Y. ,just a small business,but locally everyone uses him ,he's been at it since I was a pup and now his son is doing it,he apparently paid attention to his dad, because he is just as good.
fdny37's Avatar
fdny37 fdny37 is offline
Senior Master Bike Builder
Sportster/Buell Year #2: 1968
Other Motorcycle Year: 2014
Originally Posted by randy3934 View Post
generator on an 80s shovel?
take it down to a place that can test it for you if you don't have the tools, you'll find out what's bad, armature, fields, since you put new brushes in, if they tell you it's alright then replace regulator.
I'm sorry I should have said it is an upgrade for the genny Shovels, none the less a really nice product.
Old 2nd November 2012
Sportster/Buell Year #2: '03
+1,hcrashster,+1,hopper.
You can't afford to NOT buy a Cycle Electrics generator w/regulator.
You will just have to buy one when the other POS you buy fails.....
Stick_Man's Avatar
Stick_Man Stick_Man is offline
Sportster/Buell Model: 1981 IronHead
Other Motorcycle Model: 1975 Aermacchi/H-D SX 175
Stick_Man has a spectacular aura aboutStick_Man has a spectacular aura aboutStick_Man has a spectacular aura aboutStick_Man has a spectacular aura aboutStick_Man has a spectacular aura aboutStick_Man has a spectacular aura aboutStick_Man has a spectacular aura aboutStick_Man has a spectacular aura about
there's a cheap one for sale in the wtt wtb section
otherwise if you want to do on the cheap you have to open it up and rebuild yours.
if you know for sure its the gen take it apart. I always find the arm gets cooked on mine when I run with the battery low
I take mine to an electric auto guy who tests the arm
do not buy any cheap chinese/taiwan etc parts or gens like from jireh especially. they are a waste. i have had 2 and neither last longer than 2 weeks. I've had one last 2 days. i also see no need to pay 400 dollars for something i can rebuild in 30 minutes but you need quality parts
Hopper's Avatar
Hopper Hopper is offline
Other Motorcycle Year: 1942
Please heed this wisdom. We have heard it on here before, over and over.
Old 3rd November 2012
cajun1957a cajun1957a is offline
cajun1957a is a glorious beacon of lightcajun1957a is a glorious beacon of lightcajun1957a is a glorious beacon of lightcajun1957a is a glorious beacon of lightcajun1957a is a glorious beacon of lightcajun1957a is a glorious beacon of lightcajun1957a is a glorious beacon of lightcajun1957a is a glorious beacon of lightcajun1957a is a glorious beacon of lightcajun1957a is a glorious beacon of lightcajun1957a is a glorious beacon of light
Here is a question Ive never heard asked or answered here at least that i can remember. How are the Cycle Electric gennys for noise as apposed to any other?
randy
scottfisher's Avatar
scottfisher scottfisher is offline
Sportster/Buell Model: FLCH
Sportster/Buell Year: 61
Sportster/Buell Year #2: 60
scottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to behold
what kind of noise?
Scott
'61 'CH
'60 'CH
Well all gennys make noise. I have a stethescope that i listen with, and i have always heard a crunching sound coming from every one i have ever seen. Although I have never had a CE. I bought a genny from Jireh four years ago and it has yet to let me down. I have removed it from the bike perhaps seven or eight times over those years for various other reasons and have yet to re polarize it. I am lucky by all accounts from this forum as to its working without fail. But im always chasing any little rattles and clangs and bangs and am wondering if they are quieter than the cheap aftermarkets. That would be the only reason I would buy one since i have had good luck with the other. And yes gentlemen I do know they are the best, but up here in Canada, at $500+ just cuz someone says they are the best, doesnt quite put me over the top.................Yet. Just wondering
randy
randy
ezmerf's Avatar
ezmerf ezmerf is offline
Sportster/Buell Model #2: XLS
Sportster/Buell Year #2: 1980
ezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant future
Cajun U may remember this guy on this forum he builds a alternator coversion and I think it was around the $500. price range but here alternator conversion
Murphy's Law :vvet:
