0 need help with 68 XLH
Last Post: andy2175m4
Last Post: toe
0 Mainshaft Oil Seal Leak
Last Post: mac93
0 For Sale 2003 XL883C 1200 Conversion
Last Post: webrehm
Last Post: maltesefalcon
0 What oil temp do you run
Last Post: 99-883-c
Last Post: Fivecats
0 Carb ???
0 2021 Iron Butt Rally
0 Indicators not flashing
0 It's Glamazon's Birthday!
Last Post: Veeflys
0 First start question
Last Post: 72HOGXLCH
0 HSR idle mixture screw
0 "S" model specific Q&A
Last Post: Edster
883, 883l, sportster 883
Old 24th September 2013
09SportsterDad 09SportsterDad is offline
Sportster/Buell Model: XL883L
09SportsterDad is an unknown quantity at this point
Default xl883l questions (Taller Shocks)
I've got an xl883 low, it rides a bit bumpy as expected from it being a low model.
does anyone know if I can put on taller shocks and basically get the ground clearance of a standard of a custom?
Yes you can, be cautious on your next ride out as you may find some minor handling changes coming into the picture. Oh, and welcome to the forum.
I.B.A.#26543,
Folkie's Avatar
Folkie Folkie is offline
Brass Nut
Sportster/Buell Year: 2015
Hi 09SportsterDad, welcome to the Forum.
You started your thread in the 'Forum FAQ / How To' section, which is for posts about the Forum, and how to use the forum functions, so I've moved it to the 'Suspension, Frame, Forks, … ' section.
Folkie
South East England Riders
Old 25th September 2013
XLXR's Avatar
XLXR XLXR is offline
Biggest problem of raising the rear is the front starts to feel too soft, so expect to fix the front also. Be careful on the first test ride to ensure you don't end up with a high speed wobble. Do a gentle bump on one side of the handle bars at low speeds, then speed up and repeat only if no wobble is noticed.
You probably have to loosen the drive belt to avoid binding up rear suspension travel.
Read the "7 Pages of Suspension" in the Suspension Sticky Index Section for more info.
