0 The One Who Likes Pineapple
Last Post: Fifty150
Last Post: Fifty150
0 Off Road Lights
Last Post: Fifty150
Last Post: Hopper
0 Sportster S on the dyno
Last Post: crfblur
0 HSR idle mixture screw
0 First start question
Last Post: Fivecats
Last Post: Turbo Sporty 48
0 Should I buy a Sportster??
Last Post: riceburner
0 Front deflection
Last Post: denguy
Last Post: Fivecats
0 Ran out of gas.
Last Post: Hellbent_4
0 Best seat for long rides
Last Post: Diogenes415
0 need help with 68 XLH
0 2021 Iron Butt Rally
1983, charging problem, generator, ironhead, xlh
Old 16th June 2015
Steelhead760 Steelhead760 is offline
Sportster/Buell Model: Xlh 1000
Steelhead760 is an unknown quantity at this point
Default generator issues
hello friends, today i found out my stalling problem was due to my generator.
My battery is only testing at 12.5 while running and not receiving a charge from the generator. even at 2000 rpm it reads 12.5 and lower.
I've tried polarizing the generator but it still wasn't making a charge.
HELP lol
Old 16th June 2015
IronHead78's Avatar
IronHead78 IronHead78 is offline
Sportster/Buell Year: 78
IronHead78 has a spectacular aura aboutIronHead78 has a spectacular aura aboutIronHead78 has a spectacular aura aboutIronHead78 has a spectacular aura aboutIronHead78 has a spectacular aura aboutIronHead78 has a spectacular aura aboutIronHead78 has a spectacular aura aboutIronHead78 has a spectacular aura aboutIronHead78 has a spectacular aura about
Check your brushes, it's most likely your problem. You need have an excess of a 1/2" in brush length. I have to change mine every year or two depending on mileage, the after market brushes don't seem to last as long as ome. If you are unsure of the process there is at least one thread on the process in the sticky section.
78 sportster, Weisco pistions,Andrews Y cams, Kibblewhite valves with Manley springs, ported and polished heads with an SS super E.
Old 16th June 2015
Yellowstone Kelly's Avatar
Ironhead Rider
Sportster/Buell Year: 1982
Sportster/Buell Year #2: 1969
Other Motorcycle Model: FLSTC
Other Motorcycle Year: 1996
Yellowstone Kelly has a reputation beyond reputeYellowstone Kelly has a reputation beyond reputeYellowstone Kelly has a reputation beyond reputeYellowstone Kelly has a reputation beyond reputeYellowstone Kelly has a reputation beyond reputeYellowstone Kelly has a reputation beyond reputeYellowstone Kelly has a reputation beyond reputeYellowstone Kelly has a reputation beyond reputeYellowstone Kelly has a reputation beyond reputeYellowstone Kelly has a reputation beyond reputeYellowstone Kelly has a reputation beyond repute
Here's the link to the sticky mentioned by Ironhead78.
http://xlforum.net/forums/s...ad.php?t=39146
Checking the brushes is a good idea, use the procedure in the sticky to find the problem if the brushes are good.
Old 16th June 2015
Scuba10jdl's Avatar
Sportster/Buell Year #2: 1972
Have you done the output tests as mentioned in the sticky by Yellowstone Kelly? That's the only way to verify the issue. When my bike had a bad regulator it never charged either, but the gen. was completely fine.
[IMG]http://i.imgur.com/Oe4Ttw0.png[/IMG][IMG]https://i.imgur.com/AFv3AMo.jpg?1[/IMG]
Old 17th June 2015
So i got the generator off and tried to hook it up to a battery to see if it will spin. But it wont spin does that mean it is bad?
Old 17th June 2015
brianbbs67's Avatar
Reformed Savant
Sportster/Buell Year: 1961
Sportster/Buell Year #2: 1970
Other Motorcycle Year: 1977
Did you do it this way, with good grounds?
9. Here's a good way to bench test your generator:
Contributed by Bowtied
1. connect a jumper from the "+" battery post to the "A" armature terminal on the gen.
2. Connect a jumper from the "-" battery post to the "F" field terminal of the gen.
3. Now take a third jumper from the "-" battery post and touch it to the case of the gen.
If all is well the generator will run like an electric motor. With the gen gear pointing away from you the rotation is clockwise.
Old 17th June 2015
Okay it worked so does that mean i just need to clean my brushes and stuff?
Or would a bad regulator keep it from charging as well
Old 17th June 2015
Old 17th June 2015
brianbbs67's Avatar
Reformed Savant
Can't comment on your brushes and stuff. Haven't seen.
But a bad regulator could stop voltage to battery or give it way too much.
Old 17th June 2015
scottfisher's Avatar
scottfisher scottfisher is offline
Sportster/Buell Model: FLCH
Sportster/Buell Year: 61
Sportster/Buell Year #2: 60
scottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to behold
From the Stickys:
http://xlforum.net/forums/s....php?t=1085926
this is the best genny repair thread. It outlines step by step the diagnostic process to problem solve and repair your genny.
s
Scott
'61 'CH
'60 'CH
