Last Post: 73HEAD
Last Post: cazz1000
Last Post: Captain Johnny
Last Post: jcro61
0 Lurker from the SF Bay Area
Last Post: calileo
5 Rethinking 1250 Build
0 First start question
Last Post: MikeBel
0 Should I buy a Sportster??
0 Exhaust question
Last Post: Monte03
0 Bassani Baffle Supplier
0 Timing, static or strobe?
0 Starter Relay?
Last Post: xena
Last Post: Andy56
0 33.4mm fork bushings
0 help with stuck engine
doughboy (68), tinman (66), mofo (59), JAFI (58), Topgun (56), Hogwylde (56), Pay Toilet (55), grwhite038 (53), JWG883 (52), sorryifitburns (48), Leibniz (46), higgins14 (44)
cv carb, sputtering
Old 21st August 2015
jlongbrake's Avatar
jlongbrake jlongbrake is offline
Sportster/Buell Model: 883 Sportster
Sportster/Buell Model #2: Iron Head
Sportster/Buell Year #2: 1983
Other Motorcycle Year: 1998
jlongbrake is just really nicejlongbrake is just really nicejlongbrake is just really nicejlongbrake is just really nicejlongbrake is just really nicejlongbrake is just really nicejlongbrake is just really nicejlongbrake is just really nicejlongbrake is just really nicejlongbrake is just really nicejlongbrake is just really nice
Default sputtering issues
So my 02' sportster has had some issues with sputtering. Started this season. When I get on it it hesitates and sputters. If I ease into the throttle and gradually pick up speed it's fine, but if I hammer into it, it sputters. But today it acts like I'm running out of gas. first three gears is terrible, but 4th and fifth have no problem. Instead of baaaaaaaaaaa. I get babababaaaabababa. If that makes sense.
I thought maybe adjusting the enrichment screw. Possible too lean or too rich. I also thought fuel filter, but it idles fine and 4th and 5th are fine.
Thoughts?
Details: 45 slow jet. Yost power tube both installed nine years ago.
Thank God, my daddy was a biker.
squekster's Avatar
squekster squekster is offline
Sportster/Buell Model: 883/1200 conversion
squekster has much to be proud ofsquekster has much to be proud ofsquekster has much to be proud ofsquekster has much to be proud ofsquekster has much to be proud ofsquekster has much to be proud ofsquekster has much to be proud ofsquekster has much to be proud ofsquekster has much to be proud ofsquekster has much to be proud ofsquekster has much to be proud of
Thoughts?
I would start with the basics. Check the plugs this will give you
an idea how rich or lean you are. Check accelerator pump. Check
plug wires and battery connections.
Old 25th August 2015
Sportster1200C's Avatar
Sportster1200C Sportster1200C is offline
Other Motorcycle Model: Sprint 175SX
Other Motorcycle Year: 1973
Sportster1200C is an unknown quantity at this point
Dealing with the same issue, just checked mine with carb spray around the intake and died when sprayed on the front cylinder. I'll be changing those tomorrow
