Last Post: andy2175m4
0 Carb ???
0 2021 Iron Butt Rally
0 Mainshaft Oil Seal Leak
0 Indicators not flashing
0 It's Glamazon's Birthday!
Last Post: Veeflys
0 First start question
Last Post: 72HOGXLCH
0 HSR idle mixture screw
0 "S" model specific Q&A
Last Post: Edster
5 How do I increase sag ?
0 Track Bike Build
0 Pushrod hitting tube
Last Post: DR DICK
0 need help with 68 XLH
Last Post: DR DICK
Old 20th December 2018
Randy_rots Randy_rots is offline
Sportster/Buell Model: XL 1200 softail frame&NOS
Sportster/Buell Model #2: Buell XB1250 Uly XT
Randy_rots has a brilliant futureRandy_rots has a brilliant futureRandy_rots has a brilliant futureRandy_rots has a brilliant futureRandy_rots has a brilliant futureRandy_rots has a brilliant futureRandy_rots has a brilliant futureRandy_rots has a brilliant futureRandy_rots has a brilliant futureRandy_rots has a brilliant futureRandy_rots has a brilliant future
Originally Posted by JeremyConnors View Post
Subscribed. And hoping this project is ongoing..!
Hi
It's almost done but I still need to fine tune the fuel maps.
I need to wait for spring to do it because it's too cold and too wet now.
Thanks!
Old 24th January 2019
Blue Scoot's Avatar
Blue Scoot Blue Scoot is offline
Sportster/Buell Model: XL883N
Blue Scoot has a reputation beyond reputeBlue Scoot has a reputation beyond reputeBlue Scoot has a reputation beyond reputeBlue Scoot has a reputation beyond reputeBlue Scoot has a reputation beyond reputeBlue Scoot has a reputation beyond reputeBlue Scoot has a reputation beyond reputeBlue Scoot has a reputation beyond reputeBlue Scoot has a reputation beyond reputeBlue Scoot has a reputation beyond reputeBlue Scoot has a reputation beyond repute
I know it's not spring yet, but have you made any more progress?
Keep us updated when you do since I would really like to know how this is working for you!
-Sent from my BlackBerry
2013 Iron 883 to 1200 @113k miles and counting...
JeremyConnors JeremyConnors is offline
Sportster/Buell Model: XR1200
Sportster/Buell Year: 2012
JeremyConnors is an unknown quantity at this point
Default I understand...
Originally Posted by Randy_rots View Post
Hi
Thanks!
This isn’t BadWeatherBikers afterall.
(I trust you’ll get that reference.)
Old 25th January 2019
It's not that I don't ride it in the rain
It is simply too dangerous to road test and log with WOT on wet road
I will be working on it as soon as the weather will be good again.
This guy was helping me to tune it:
https://www.buelltooth.com/tunabuell.html
Unfortunately, he started to give up when his tunes were not working too well with my own Innovate dual wide band sensors :/
I think that everything was going well, but because we had to stat over at least 3 times and then stop because we needed bigger injectors, then new ignition maps and I went away for vacations, he has lost his faith...
I still have left 3 sessions paid and I hope he won't let me down.
After all it was his own decision to try to tune it with my Innovate dual wide band sensors. I was prepared to buy his own tool to do it but he wanted to give it a shot.
Pitty, that it turned out to be too difficult for him to figure out the other system :/
I have spent too much time and money to give up at this point, so I will get it done no matter what
Regards
Old 7th February 2019
firemanjim firemanjim is offline
Sportster/Buell Model: S-2
firemanjim has disabled reputation
Not sure why he could not use the Innovate wide bands, they all output a 0-5 volt signal. And I bet you can look up what voltage equals what AFR on Innovate site.
Old 16th February 2019
Hi
I set up both wide bands correctly, and I sent him loads of data.
I was feeling improvement each time I burned updated maps.
The problem was that we have done about 4 sessions and found out that the injectors were too small, so I installed new set and we had to start over again.
Then after about 4 sessions he has decided to use new timing maps from Hammer Perf and... we had to start over again, LOL.
We have done another few session and the bike started to run better and better, after each session. However, I ran out of time and we stopped with intention to continue after my vacations. Unfortunately when I got back, he was reluctant to continue :/ He still owe me few sessions and I hope he will do it for me this spring.
Regarding the Innovate, he was complaining that it gives him slightly different data than his own wide band kit, hence the problems with quick tuning.
I told him right on the start that I can buy his wide band kit if he wants but he said that Innovate should be fine...
There's also some problems with idle that he has promised to fix.
I think that I will contact Andy Whittle (the Youtuber) and send him my maps to analyze, looking from his videos, he has enough knowledge to recognize the problem right away. I'm not sure if he will be willing too do so.
Regards
Old 19th March 2020
Highly-Dangerous's Avatar
...... and?????
[B][COLOR="Red"]CLICK->>[/COLOR][URL="http://sportsterpedia.com/doku.php/start"]"Maintenance is as much art as it is science"[/URL][COLOR="red"]<<-CLICK[/COLOR][/B]
[IMG]http://xlforum.net/forums/attachment.php?attachmentid=20617&d=1576580635[/IMG]
Old 19th March 2020
Originally Posted by Highly-Dangerous View Post
...... and?????
And... I have contacted Andy over a year ago and initially he agreed to help but then he stopped responding and also I did not see him active on his YT channel...
So, I don't know what to do.
Old 21st March 2020
No reason you can't do this yourself.Not rocket science. And this is just a 1250?? No reason you needed bigger injectors, even the 88 inch motors just needed more fuel pressure from the upgraded fuel pressure regulator. heck, I can show you how to add more fuel over the entire map in ECM-Spy. You have the needed data. What are you using to tune the maps?
Old 22nd March 2020
Hi
Well, you can help me with it if you like. Thanks for the offer.
I did not have time to do it myself and that was the reason I went that way.
I paid the guy and he still did not finish the job (he still owe me for 4 sessions).
Also, I did not want to mess with it before he finish.
Regarding Andy Whittle, I started to watch his YT movies and found this one:
https://www.youtube.com/watch?v=eF_uAxpbzCw
I had this problem since I bought this bike in stock form and it's still there.
I have ECM Spy mono and Buelltooth and ECMDroid.
Regards
