0 Gear indicator missing
Last Post: Shahyaan
0 Transmission drain plug
Last Post: mvent
0 Indicators not flashing
Last Post: IronHeadRon
0 1975 Sportster
Last Post: duffy
0 1982 rubber oil hoses
Last Post: Porkchop9
0 1975 Sportster
Last Post: Gulf Coaster
Last Post: Bikeaholic
Last Post: Animosity
Last Post: SophieWillow
Last Post: 84rzv500r
5 1975 Sportster
Last Post: Whitewalls
0 Carb ???
Last Post: mikethebike61
Johnc (75), x750rider (68), bart53 (68), bad rad (67), halfdrive (56), jag1 (49), Zuhaib (37)
Old 10th October 2017
atungate atungate is offline
Sportster/Buell Model: s1 sporty
Sportster/Buell Year: 90/9
atungate is an unknown quantity at this point
Default 1997 S1 forks on 1990 sportster frame
I have s1 forks, triple trees, and caliper. My triple trees have no axe & I don't have an axle for my wheel. I have no wheel plan on using my sporty mag. Can anyone give me any advice on what I will have to have for this swap?
Sent from my SM-J327V using Tapatalk
Here's the parts page from Ronnie's for the 1990-1200...
Here's the parts page from Ronnies for the 1997-Sport...
You can do necessary part number comparisons between the two...
The international lower TT with Stem is the same part number in 1990 as for the 1997-Sport - So that should mount up --- You'll need to complete the wheel, bearings & axle with compatible parts for the 1997-Sport forks...
See the Sportsterpedia listing here:
http://sportsterpedia.com/doku.php/t...k:evo:wheels01
IXL 2 Relax
>>>> My Build & Ride Reports Are Here <<<<
Reference the Sportsterpedia
A FREE XLForum collection of technical info & advice
Thank you ixl2relax but I'm sorry I guess I was unclear. The forks & tt's I have are off of a 97 buell s1 lightening, not a sportster. But I plan on trying to use my sporty 19" mag.
I guess I mis-read the S1 as SPORT...
Anyway - Try this:
http://xlforum.net/forums/s...ad.php?t=33810
Something here might also be of interest:
http://xlforum.net/forums/s....php?t=1073108
If I find any other relevant threads, I'll post them into this post - so check again...
IXL 2 Relax
