0 The One Who Likes Pineapple
Last Post: Fifty150
Last Post: Fifty150
0 Off Road Lights
Last Post: Fifty150
Last Post: Hopper
0 Sportster S on the dyno
Last Post: crfblur
0 HSR idle mixture screw
0 First start question
Last Post: Fivecats
Last Post: Turbo Sporty 48
0 Should I buy a Sportster??
Last Post: riceburner
0 Front deflection
Last Post: denguy
Last Post: Fivecats
0 Ran out of gas.
Last Post: Hellbent_4
0 Best seat for long rides
Last Post: Diogenes415
0 need help with 68 XLH
cam timing, generator, pinion gear
Old 8th August 2019
olander olander is offline
Sportster/Buell Year: 1967
olander is an unknown quantity at this point
No damage to the valves. Actually no damage at all anywhere. Guess I was lucky this time
Old 8th August 2019
Sportster/Buell Year #2: '03
I've also put a valve impression into a piston dome.the steel valve survived the pushrod bent.i've bent valves when they got stuck in the new guides.steel valves colliding will not survive.all 4 brand new valves had to be replaced.
Old 11th August 2019
farmall farmall is offline
Sportster/Buell Year: 73
farmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond repute
A spun press fit is now a worn press fit. I've not personally degreed then TIG welded cam eggs to shafts as I don't mess with racing 45s etc, but I'm sure someone here has who can offer advice. Unless the cams are expen$ive aftermarket parts you REALLY need to save I'd replace them as a set. Good time to upgrade..
Old 12th August 2019
I ended up reading this thread: http://xlforum.net/forums/showthread.php?t=1222275
So I will replace my PB cam for the original B cam. Since I’m just cruising with by bike I think they are a better fit.
