Last Post: handa700
Last Post: d10221
0 Gear and brake linkage
Last Post: Andy56
0 Oil pressure switch
0 need help with 68 XLH
0 Valve Stem Seal ID
Last Post: BruceM
0 What oil temp do you run
0 Clutch Spring plate poll
0 why you can't be seen
Last Post: Les59
0 HSR idle mixture screw
Last Post: Hardtail28
0 Front deflection
Old 8th March 2020
rejeanprimeau's Avatar
Any regulator rated 20amp and + will work.
Old 8th March 2020
ParrotHead's Avatar
Other Motorcycle Year: 1974
Stator not grounded, just checked with test light.
Output at 2000 rpm is only 7 volts so I think I found my problem
John Wayne - "The Shootist"
Click here
to listen to my interview on the Chasing the Horizon Podcast
Old 8th March 2020
decman decman is offline
Post no Avatars!
Sportster/Buell Year #2: 1988
Other Motorcycle Model: FXDXT
Glad you found it. Hope you can get one close by.
"Adventures only suck while you are having them."
Neil Peart
Old 8th March 2020
ParrotHead's Avatar
Neil Peart
Got one in my garage but does not help me here.
I’ve been planning on replacing it with a newer 30 amp system, I guess this is my chance ...
Old 8th March 2020
I’ll agree that not difficult to replace, I’ve done way more than my share, the only difficulty comes with torquing the crankshaft nut, getting up to 240 lbs ft. Chris, thought you had already gone to the H.D. 30 amp set up, my bad.
I.B.A.#26543,
Old 8th March 2020
F.W.I.W. Cuba, Missouri is 312 miles just up I-44, about a 6 hour run.........
Old 8th March 2020
They do but Chris’s desire is to stay with stock H.D. parts for convenience in replacement as he does serious long distance running.
Sorry for jumping in Chris, thought your plate might be full at the moment.
Old 8th March 2020
Tomcatt Tomcatt is offline
Dazed & Confused
Other Motorcycle Year: 2015
Yeah, I had deleted my post. Wrong time and place for that discussion.
Old 9th March 2020
Any H-D or After-market regulator will work. The dealer must have at least one regulator at hand. 32amp or 20 amp will work; they regulated voltage not amperage. The difference is the size of the wires.
Old 9th March 2020
NOTE: Chris determined the stator was only outputing 7v at 2000rpm - The regulator may be OK...
Here's the Sportsterpedia section on the Charging System:
http://sportsterpedia.com/doku.php/t...harging_system
The Stator Connector on the regulator for 2004-2006 is the same as for 1991-2003 - So the stator part number needed (compatible from 1991-2006) is 29967-89C...
So - Anyone in that area with a spare stator for a 1991-2006 model would be compatible to what Chris needs... Presuming his regulator is still functioning correctly...
If he also needs a regulator, the part number for a 2004-2006 unit is 74523-04, which has the right output connector to match the wire harness...
