0 Mainshaft Oil Seal Leak
Last Post: mac93
0 For Sale 2003 XL883C 1200 Conversion
Last Post: webrehm
Last Post: maltesefalcon
0 What oil temp do you run
Last Post: 99-883-c
Last Post: Fivecats
0 Carb ???
0 2021 Iron Butt Rally
0 Indicators not flashing
0 It's Glamazon's Birthday!
Last Post: Veeflys
0 First start question
Last Post: 72HOGXLCH
0 HSR idle mixture screw
0 "S" model specific Q&A
Last Post: Edster
5 How do I increase sag ?
883l, hub, spoke
Old 25th January 2021
Ed.K Ed.K is offline
Sportster/Buell Model: 883L
Sportster/Buell Year: 2012
Ed.K is an unknown quantity at this point
Default 2012 883L mag to 16" spoke wheel
I am thinking to change my 2012 883L mag wheel to 16" front and rear spoke, does anyone know which year model hub is interchangeable without replacing the spacer?
Thanks in advance!
Tomcatt Tomcatt is offline
Dazed & Confused
Other Motorcycle Year: 2015
Too bad you're not closer. I have a set of virtually new 16" spoked wheels and tires off my '17 Custom sitting here that I replaced with cast wheels.
When I swapped mine I used: http://sportsterpedia.com/doku.php/t...k:evo:wheels01 and HD parts fiches to figure out which wheels interchanged.
Bluto Bluto is offline
Other Motorcycle Model: Norton 850 Commando
Other Motorcycle Year: 1973
AFAIK all 08+ Sportster wheels take a 25mm axle and rears should interchange no problem, I installed a 2016 rear wheel on my 08. Front fork widths vary so that is something to check spacer wise. Anyway to make sure check out spacers, bearings, etc. at https://partsfinder.onlinemicrofiche....asp?make=hdmc
Old 28th January 2021
Thanks for the information, Is Ronnies open for any customer or only for a distributor? I don't know why they block my IP while I check the part number back and forth now I have to call from Taiwan to ask them to unblock...
Dazed & Confused
It's for customers. I open multiple tabs with one fiche each when comparing and haven't had problems.
+1, have been using Ronnies Parts Finder for 3 years and never had a problem unless their site was down completely. Online US based HD parts vendors won't ship overseas (maybe be some contractual deal with HD ?) so that might be the reason for the IP block. Working currently for me...
Dazed & Confused
+...(maybe be some contractual deal with HD ?)...
Yes, HD has restrictions. It's spelled out on Ronnies' site.
Old 29th January 2021
I tried it again today it works! this time I open multiple tabs no problems show up, many thanks!
