0 need help with 68 XLH
Last Post: fafcpa
0 Track Bike Build
Last Post: Tippy_Toes
Last Post: handa700
Last Post: d10221
0 Gear and brake linkage
Last Post: Andy56
0 Oil pressure switch
0 Valve Stem Seal ID
Last Post: BruceM
0 What oil temp do you run
0 Clutch Spring plate poll
0 why you can't be seen
Last Post: Les59
0 HSR idle mixture screw
Old 28th February 2021
Azmarlin39a's Avatar
Azmarlin39a Azmarlin39a is offline
Sportster/Buell Model: XL1200NS
Sportster/Buell Year: 2020
Azmarlin39a is an unknown quantity at this point
Default Crash Bar
I’m going to order a crash bar for my sportster. I looked at the install video on YouTube and like the look.
Old 2nd March 2021
bordens bordens is offline
bordens is an unknown quantity at this point
Crash bars look fine though I don't like them personally.
Old 2nd March 2021
Andy56 Andy56 is offline
Andy56 has much to be proud ofAndy56 has much to be proud ofAndy56 has much to be proud ofAndy56 has much to be proud ofAndy56 has much to be proud ofAndy56 has much to be proud ofAndy56 has much to be proud ofAndy56 has much to be proud ofAndy56 has much to be proud ofAndy56 has much to be proud ofAndy56 has much to be proud of
The bottom bolt holes are a cross member on the frame already tapped. The top holes are shared with the engine mount. The bar comes with longer bolts.
HD tells you they are not crash bars and will not protect you. They call them engine guards as in protection from dropping the bike at low speed or when stationary.
I have the basic no frills one on my bike.
Old 2nd March 2021
BKB's Avatar
BKB BKB is offline
I think they're kinda ugly, but I'm old & it makes it a lot easier to pick up when I drop it.
Old 2nd March 2021
45Brit 45Brit is offline
Sportster/Buell Model #2: 1978 XLCH project
Other Motorcycle Year: 1975
45Brit has a reputation beyond repute45Brit has a reputation beyond repute45Brit has a reputation beyond repute45Brit has a reputation beyond repute45Brit has a reputation beyond repute45Brit has a reputation beyond repute45Brit has a reputation beyond repute45Brit has a reputation beyond repute45Brit has a reputation beyond repute45Brit has a reputation beyond repute45Brit has a reputation beyond repute
I had a 600lb, 74”twin with a 61” wheelbase... it was called a Shovelhead...
Old 2nd March 2021
Tim The Grim's Avatar
MetalWorkingXLFan
Sportster/Buell Model #2: KHK
Sportster/Buell Year #2: 1954
Other Motorcycle Year: 97
I have the “ mustache “ type and added some LEDs.
Old 3rd March 2021
SLW210 SLW210 is offline
Sportster/Buell Model: 1
SLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond repute
I took my engine guard off the Sportster and the LowRider didn't have one. Thought about getting or making a Bung King style, they look good and work.
