0 Tank and petcock identification
Last Post: Gravitas
Last Post: Fifty150
Last Post: Fivecats
0 Lurker from the SF Bay Area
0 First start question
0 Should I buy a Sportster??
Last Post: riceburner
0 cleaning your sporty
Last Post: Fifty150
Last Post: mac93
0 2021 Iron Butt Rally
0 Valve Stem Seal ID
0 Electrical almost all sorted
Last Post: Ark OB
0 The Little Things - Multi-Part Series on Mods That Make The MOST Difference!
0 The argument for getting a custom seat
Last Post: BestCoastXL
0 Riding The Badlands in 2021
0 Old School Look
Last Post: Bikeaholic
Old 6th August 2021
BestCoastXL's Avatar
BestCoastXL BestCoastXL is offline
Disassembly Specialist
Sportster/Buell Model: XL883L
Sportster/Buell Model #2: XL883L/1275
BestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond repute
Talking Combustion Industries Sissy Bar and R9 Kustoms Duffel
During my frame-up build I decided to invest in some type of luggage that would be practical and hold up over time.
Since I was going with a "bobber" style for that bike, chopped fender struts were an automatic and since the frame was powdercoated to a satin metallic gunmetal, a matching luggage support was a no brainer.
I started off with buddy bending up some thick rod and trying my hand at welding but it just wasn't getting the look or function or mounting that I was after.
Enter Combustion Industries for the sissy bar and R9 Kustoms for the bag.
The bag has rubber backed tartan material lining the inside, heavy duty hardware and thick leather. The over the top feature was the corset for cinching it up to the sissy bar. It comes with a shoulder strap so you can take it with you on your over night trips. It's also available in black with the same heavy duty canvas. Storm covers with elastic bottoms available as well. There's a TON of space in this bag!
The sissy bar was custom made for chopped fender struts. Combustion Industries really went the extra mile to fit the bar to the inside of the fender struts, but you could order it to fit along the outside between the strut and shock bolt. The rack folds up and stays up with a set screw if you're not hauling. You can have the bar do double duty with a bag on the front and a sleeping bag or gas container strapped out back.
I chose to order mine raw but they come powdercoated if you opt for that. Both high quality items. 200% recommended for that scoot that doesn't want to have an identity crisis as a road sofa.
Items found here:
https://r9kustoms.com/sissy-bar-duffle-bag/
https://www.combustionindustries.com/shop-1
Sissifigurator for custom ordering your perfect Sissy Bar found here:
https://www.combustionindustries.com/sissymaker
<a href=https://ibb.co/ZgNBvMD target=_blank><img src=https://i.ibb.co/ZgNBvMD/7-D0-F1204-1-C70-4-C4-B-B43-B-0699-A25-BAB0-F.jpg border=0 alt= /></a>[/SIGPIC]"It's always either something simple or something stupid"
Current Build '05 XL883L -->1275 Basic Kit, Cometic Gasket Kit (THE CORRECT ONE), Colony Fasteners Kit, Extra Plate Clutch, 38tooth Primary, 07+ oil pump upgrade
D cams, Hammer Pushrods, stock heads, S&S Precision Hydraulic Lifters, CV Performance CV40 Carb upgrade with EZ-Justs and V-Ductor
Arlen Air Cleaner, DK filter relocation, DK 4 stage EBS
Custom 1-piece front fender and swingarm-mounted rear fender, paint and pinstriping (done by me)
R9 Kustoms Duffel Bag & Combustion Industries Custom sissy bar for chopped fender struts
Rick's Motorsport LiFePO4 Reg/Rec, Upgraded CE Stator & Solid Rotor
TC88A sensor harness, coil, All Balls Racing 1.4KW Starter, 4AWG feed, Antigravity Lithium Battery with Restart function
Motogadget: m-unit, motoscope mini w/gauge holder & indicators, m button, m switch minis, m lock, inverted all-in-one tail light on custom altered stock seat, Kellerman Bullet R/B/T 1000's, Speedmotoco 8" LED DRL Projector headlight
Custom powdercoated frame with internal wiring, Custom electronics & battery enclosure, Goodridge SS rear brake line
D&D Bobcat 2-1
Lowbrow Customs Pursuit Brass pegs, shifters and grips, TC Bros Fwd controls
Custom oil tank with brass "non-vented" cap, Black braided AN6 fitting oil lines
DK Rocker Lockers (yes they work)
HP: Don' know, Don't care
Old 12th August 2021
R9Kustoms's Avatar
R9Kustoms R9Kustoms is offline
Sportster/Buell Model: Xb12R
R9Kustoms is an unknown quantity at this point
Hey mate!!! Thanks for sharing our bag, looks bloody awesome on the bike!! Stay upright! Cheers
Old 13th August 2021
You bet! My buddy ordered one for his scoot as well in black the bery next day after he tried mine on his. He also got one of those sweet tool rolls you just came out with!
Could you post a link here for both?
R9Kustoms's Avatar
I'll send you a PM
Old 15th August 2021
done and done.
