Last Post: Fifty150
Last Post: Fivecats
0 Lurker from the SF Bay Area
0 First start question
0 Should I buy a Sportster??
Last Post: riceburner
0 cleaning your sporty
Last Post: Fifty150
Last Post: mac93
0 2021 Iron Butt Rally
0 Tank and petcock identification
0 Valve Stem Seal ID
0 Electrical almost all sorted
Last Post: Ark OB
0 The Little Things - Multi-Part Series on Mods That Make The MOST Difference!
0 The argument for getting a custom seat
Last Post: BestCoastXL
0 Riding The Badlands in 2021
0 Old School Look
Last Post: Bikeaholic
  #281
Old 5th September 2011
d0gsnot's Avatar
d0gsnot d0gsnot is offline
d0gsnot has a spectacular aura aboutd0gsnot has a spectacular aura aboutd0gsnot has a spectacular aura aboutd0gsnot has a spectacular aura aboutd0gsnot has a spectacular aura aboutd0gsnot has a spectacular aura aboutd0gsnot has a spectacular aura aboutd0gsnot has a spectacular aura aboutd0gsnot has a spectacular aura aboutd0gsnot has a spectacular aura aboutd0gsnot has a spectacular aura about
Ah, I just watched the vid and realized the question Brian was asking me was if "Boomer" was my dog, that my wife says his name at the beginning. It is more an avatar of my attitude when I am in city traffic. Sometimes, that is what I feel like when I get cut off or am being tailgated by cagers. Sorry, bald moment!
Old 7th September 2011
brianq103's Avatar
brianq103 brianq103 is offline
Sportster/Buell Model: Ultra Limited
Sportster/Buell Year: 2016
Other Motorcycle Model: Ducati Monster 1200S
Other Motorcycle Year: 2014
brianq103 is a name known to allbrianq103 is a name known to allbrianq103 is a name known to allbrianq103 is a name known to allbrianq103 is a name known to allbrianq103 is a name known to allbrianq103 is a name known to allbrianq103 is a name known to allbrianq103 is a name known to allbrianq103 is a name known to allbrianq103 is a name known to all
I'm not surprised it didn't make any sense-you were posting the vid to demonstrate the horn not your dog!
It sounds like the "chrome" Stebel isn't worth the extra money, so I think that the plain one will be the one I go with. I like the looks of the all black. Is there a special paint that you used?
[SIGPIC][/SIGPIC]
d0gsnot's Avatar
First,I masked it off with masking tape, then scuffed it with scotchbrite and wiped clean with alcohol. Primered it with a chromate primer and then shot a coat of polyurethane low gloss black on it. Easy enough.
Old 7th February 2014
maurino17's Avatar
maurino17 maurino17 is offline
Sportster/Buell Model: 2005 883R
maurino17 is a name known to allmaurino17 is a name known to allmaurino17 is a name known to allmaurino17 is a name known to allmaurino17 is a name known to allmaurino17 is a name known to allmaurino17 is a name known to allmaurino17 is a name known to allmaurino17 is a name known to allmaurino17 is a name known to allmaurino17 is a name known to all
hi
Just starting to research horns and understanding relays. I know this is years old but I had to comment this is the best explanation of a "relay" I have found! I have been reading and searching to understand the relay and this was perfect, thanks!
Originally Posted by thunderpaw View Post
Vince, the reason for the relay is current draw. Dual horns or these air horns pull a lot of current. Without using a relay, all that current is going through your handlebar switch-most likely more amperage than it was designed to handle. While it will work, it is not uncommon for such a load to prematurely burn out the switch (also the wire going to and from the switch isn't large enough to carry the full current that the horn(s) were designed for(not talking about the 'meep-meep' horn). By using a relay, the handlebar switch only handles the low current involved in activating the relay...the big load is handled by the relay itself (the typical Bosch style relay is rated from between 25-30 amps). Another benefit from using the relay is that the horns may actually perform better by getting the current that they need to reach their full potential volume.
Not to mention that an internal melt-down of a wiring harness is enough to ruin your day
Kim
Old 22nd July 2014
Devils Cut's Avatar
Devils Cut Devils Cut is offline
Sportster/Buell Model: sportstet
Sportster/Buell Model #2: 1200 $portstet C
Other Motorcycle Model: 1975 hondra xl 70
Devils Cut is an unknown quantity at this point
That looks like something I need to put on mine .
Old 5th September 2016
old geezer's Avatar
old geezer old geezer is offline
Sportster/Buell Model: xl883n Iron
old geezer is an unknown quantity at this point
I'm a little late to the dance on this, but I just installed a stebel on my 2010 iron. Thank you guys for all the information. I did a simple function over form install and mounted it
on the right side fender strut by the rear taillight with a very simple homemade bracket. Very loud and positioned to blare at the idiots on the right floating into my lane.
Old 17th September 2016
old geezer's Avatar
Update: Had to use the horn out of defense mood, worked great, stopped the old coot from taking me out. We were side by side, he is looking in his mirror but not me right beside him. The horns woke him up real quick.
Old enough to have known better.
ChinCactus's Avatar
Glad worked! I didn't read the whole thread so this may have been mentioned before.
These horns are also marketed as the Wolo Bad Boy. If you search around you can get the chrome version for around 40 bucks.
Kuryaykn also makes a chrome cover for them.
