0 Transmission drain plug
Last Post: roadsterboy
0 1975 Sportster
Last Post: alsfarms
0 2003 Custom 1200
0 Clutch issue
Last Post: Fivecats
Last Post: SophieWillow
0 Indicators not flashing
0 Gear indicator missing
Last Post: duffy
0 1982 rubber oil hoses
Last Post: Porkchop9
0 1975 Sportster
Last Post: Bikeaholic
Last Post: Animosity
Last Post: 84rzv500r
Snuffy (72), cabby58 (63), SmoothyB (54), johnnyB (52), cayey (51), BIGschwerm (45), chief (45), Sporty Accorn (45), Muddypunk (36), Andreas (34)
air cleaner, cv carb, exposed, ironhead, water
Old 17th July 2010
rivethog's Avatar
rivethog rivethog is offline
Sportster/Buell Year: '78
Sportster/Buell Model #2: 883 XLH
Sportster/Buell Year #2: 1993
Other Motorcycle Model: 93" Shovel/Pan
Other Motorcycle Year: 1967
rivethog has disabled reputation
In the past I've used K&N, oiled foam, pleated paper, & stock wire mesh. I like the stock style oiled foam type filter best. I use UNI brand, but any quality brand of oiled foam filter works well. It's easy to service and lasts a long time. I'm not worried that I might be losing 1/100th of a HP due to it not being as free flowing as a K&N supposedly is.
ACE Hardware gr. 8 bolts Krylon & Rustoleum "premium" paint JT-6 waterproof grease, Emgo oil filter Loctite blue red & green AutoZone headlight bulb soxxet genuine Aftermarket rear fender generic countershaft sproxxet Radio Shaxx 16ga & 14ga wire forks off of a 180mph drag bike Swallow 4.60H18 rear tire 3.50 x 19 Shanghai front
Old 17th July 2010
merc merc is offline
Sportster/Buell Model: Custom
Other Motorcycle Model: Suzuki GN400
Other Motorcycle Year: 1980
merc has a reputation beyond reputemerc has a reputation beyond reputemerc has a reputation beyond reputemerc has a reputation beyond reputemerc has a reputation beyond reputemerc has a reputation beyond reputemerc has a reputation beyond reputemerc has a reputation beyond reputemerc has a reputation beyond reputemerc has a reputation beyond reputemerc has a reputation beyond repute
I am not saying that this guy is not a good mechanic, but I will say, from my experience that he is probably just repeating what he heard years ago and has adopted as the way to do things.
It's like saying that the reason staying away from bikers is because all bikers belong to gangs.
It's simply just not true.
I cut and made my own backing plate put a K&N filter from a Big Sucker kit, and covered it with a flat piece of brass I used for a cover. Look here:
I ran this open filter in some majors storms, many times. I don't care about weather usually. I still ride because that is my transportation to where ever I want/need to go.
One such storm was heavy rain coming down sideways with the wind pushing me across the lane. I rode it that storm for 2 and 1/2 hours. I was socked to my skibs and then some and the bike never failed. The rain had zero effect on it.
If rain was going in the carb the bike would hesitate and not even run if enough water mixed with the gas and air.
A good K&N with the red oil on it, is designed for, and does keep all foriegn material out of 6the carb.
I say go get what you want.
Old 17th July 2010
gunterjaeger's Avatar
gunterjaeger gunterjaeger is offline
Sportster/Buell Year: 72
Sportster/Buell Model #2: Sporty
Sportster/Buell Year #2: 05
gunterjaeger is a glorious beacon of lightgunterjaeger is a glorious beacon of lightgunterjaeger is a glorious beacon of lightgunterjaeger is a glorious beacon of lightgunterjaeger is a glorious beacon of lightgunterjaeger is a glorious beacon of lightgunterjaeger is a glorious beacon of lightgunterjaeger is a glorious beacon of lightgunterjaeger is a glorious beacon of lightgunterjaeger is a glorious beacon of lightgunterjaeger is a glorious beacon of light
I have a hypercharger and it remains unaffected by the rain
I'd rather die trying!
Old 17th July 2010
Originally Posted by merc View Post
... I ran this open filter in some majors storms, many times. ... I rode it that storm for 2 and 1/2 hours. ... The bike never failed. The rain had zero effect on it ..
+1
Originally Posted by gunterjaeger View Post
i have a hypercharger and it remains unaffected by the rain
+1
Old 18th December 2011
ErnieConnell's Avatar
ErnieConnell ErnieConnell is offline
Sportster/Buell Model: XLT
Other Motorcycle Model: FatBoy
Other Motorcycle Year: 1995
ErnieConnell is an unknown quantity at this point
I am running a SS Carb with the tear drop air cleaner on my "77".
My question is: Can a stock H.D. oval air cleaner/backing plate be fitted to
the SS Carb? Adaptor needed? Will the enricher lever be affected?
Trying to get a stock look.
