Last Post: Reverend G
0 Woke, cancel culture...
0 This place still sucks!!!
0 WTF Happened
0 Can you ID this bike?
0 0Salt Flat Sporton
0 Shady shifter shaft
Last Post: Captain Johnny
4 Rear Lighting WIRING help
Last Post: Cosmo Kramer
Last Post: SCarty
0 Tire Pressure 1979 XLH
Last Post: ThenCameHarry
0 Video - Does your bike REALLY need an oil cooler?
0 DK Customs Air Intake
Last Post: AZbiker
Last Post: Blacky
Last Post: XL_1200C
0 Best seat for long rides
0 Starter motor brushes? (UK)
Last Post: Loony
0 Chinese S&S carbs
0 83 XLH w/Velorex 562
Last Post: Scott
0 Rear shocks ?
Last Post: Wiktor
0 New to me 1975 sporster xlh
0 Pictures of Evos that look Like Ironheads
Last Post: 45Brit
0 Can't clear unread messages
Last Post: Brad
Last Post: Akdawg
0 Mikuni HSR42 will not idle
Mr.Gordon, rayzer13 (58), GrumpyCoyote (52), billet93 (48), beast1 (47), Barney_rubble23 (47), DDT (43), mgaworecki (42), superman5a (40), Phoenix81 (40)
  #1601
Old 3 Days Ago
Tinz Tinz is offline
Sportster/Buell Model: X1
Tinz has a reputation beyond reputeTinz has a reputation beyond reputeTinz has a reputation beyond reputeTinz has a reputation beyond reputeTinz has a reputation beyond reputeTinz has a reputation beyond reputeTinz has a reputation beyond reputeTinz has a reputation beyond reputeTinz has a reputation beyond reputeTinz has a reputation beyond reputeTinz has a reputation beyond repute
Originally Posted by cycowrencher View Post
At this kind of compression it wont matter much...
Sent from my LM-V405 using Tapatalk
Nice! Lol
Old 3 Days Ago
cycowrencher's Avatar
cycowrencher has a reputation beyond reputecycowrencher has a reputation beyond reputecycowrencher has a reputation beyond reputecycowrencher has a reputation beyond reputecycowrencher has a reputation beyond reputecycowrencher has a reputation beyond reputecycowrencher has a reputation beyond reputecycowrencher has a reputation beyond reputecycowrencher has a reputation beyond reputecycowrencher has a reputation beyond reputecycowrencher has a reputation beyond repute
There is a GRC crank service and Carrillo rods in my future... As well as Ti valves so I can spin 8500 plus.... I'll be setting the limiter at 7900 and the shift light at 7600...
Old 3 Days Ago
Ceramic top and teflon skirt.
you didn't mention the gas ports in this post. are they common with these pistons?
Old 3 Days Ago
madnss's Avatar
madnss madnss is offline
Sportster/Buell Model: 883 Xl
Just curious, why the Ti valves if you are shifting at 7600?
Old 2 Days Ago
I'm setting the light for 7600. I average about another 200rpm for the shift, and should be shifted at 78ish... The Ti valves will be next year so I can shift @ 8500...it should make power to there. I have SS valves in it now, and they are too heavy to shift that high. If I can get it to a dyno, I'm betting that when the limiter hits at 7900 the power will still be climbing with that compression and those cams... My engine guy went with some pretty hot triple valve springs just to get to 8k. He does a lot of work for Ryan T. , so Im trusting his judgment.
Old 2 Days Ago
These are a set of custom CP bullet series pistons that were originally ordered by Rat Racing for a project in 2017. Those ports are in the oil ring for oil scraping. Gas ports are usually through the crown into the top of the upper ring land. I bought them to step up the power since the turbo and custom efi was going to be more than my budget... I may still go down that road later, but this was cheaper and easier...
Old 2 Days Ago
madnss's Avatar
Default Lets see your off season builds
Nice!! Gonna be in the 9’s soon!
Sent from THEE White House
Old 2 Days Ago
Im hoping on pass 4 of licensing...
Old 2 Days Ago
thanks cycowrencher.
