0 back to factory clutch
Last Post: Bored now
0 harbor freight lift
Last Post: stick shift
0 ***DK Custom-4 Stage Vented Billet Catch Can For External Breather Systems***
0 Resto-Repair 84 ironhead
Last Post: Robyart
0 15 min rides
Last Post: CMCSSeabee
Last Post: corndog76
0 Branch Mikuni Air cleaner question
0 1960 XLCH in the UK
Last Post: lynnx
Last Post: Guidorey
0 E85 Fuel
Last Post: hondo
Last Post: fafcpa
0 Replacement Clutch/Rotor Magnets
0 97 Sportster Kickstand Problem
Last Post: Dirt Road Cowboy
0 removing clear coat on fork lowers
0 HELP! Extra part found
Last Post: syrnetworkin
0 48 O2 sensor?
Last Post: jvandivere
0 Starting issues (No Spark)
Last Post: jimstogs
0 The forum got talent
0 Battery melt down
0 Common ironhead problems
0 Hello from Tampa, Fl
Old 31st March 2012
~Grind~ ~Grind~ is offline
Sportster/Buell Year: 04
~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute
Actually, I have three versions. An EX, a RACE and a retarded version for a 1250. I just loaded it the bike last night for testing. I haven't had a chance to do the 1 mile WOT throttle test or the simulated drag race test yet. None of the versions have as much timing as you're used to and I don't know if the IA switch works with the EX maps. They are easy to modify in the software. Just open the map, left click and highlite all the cells, then right click and select modify. Say you want to advance the table by 2 degrees, just enter +2 in the box and click OK. Boom, its done. Save it, rename it, load it, ride it. Be aware that the EX format does limit the amount of advance in some areas of the map. IMO, its not in the important areas.
PM me your email and I'll send it (them) to you if you want.
"We've done four already but now we're steady
And then they went: One, two, three, four"
“The larger brush provides coverage, but is incapable of detail.” - Sherwin Williams
Old 31st March 2012
Michele, What temperature range should my oil be at? I'm going to check it and take a gander at the plugs later. I really like this thread!!!!
Old 31st March 2012
rocketmangb's Avatar
Scott
You need the oil temp high enough to cook off the moisture.
220 is fine
I have trouble getting mine that warm !
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 31st March 2012
xena's Avatar
xena xena is offline
Assistant Administrator
Every bike is different but according to HD, temps of 230
are safe. I've seen NRHS Dan say he has no worries seeing temps near 230.
XLF Rules/Guidelines
XLF Guidelines II
1212 Conversion 10:1 CR
SE 497 Cams, E1 clutch, Python 3 Slip ons
TC88A running Xena's (brand new) White Tiger Map
My 1212 Conversion Thread
Old 31st March 2012
Scott
220 is fine
Maybe you need to retard the timing a little or lean out the mixture some.
Xena wrote that when she retards the timing in her bike it runs too hot. From what I understand an overly rich condition tends to cool things down some. I've been reading up on the S&S IST. That system uses a knock sensor, and temperature sensor to help adjust timing while the bike is running. It's supposed to adjust to any engine mods you may make too! However, if you want that, you're gonna have to pay. Not cheap.
Old 1st April 2012
xena's Avatar
Forum member sportsterpaul just mentioned to
me in a pm that he has the S&S IST in his 06 1200R.
Old 1st April 2012
racerwill's Avatar
Sportster/Buell Model: XLRR
Sportster/Buell Year: 91
Sportster/Buell Year #2: 80
just a quick note on MAP(Manifold Absolute Pressure)........ first the word "absolute" refers to where zero is placed on the scale..... in PSI Absolute, 0 psi is a perfect vacuum and atmospheric pressure is 14.696 psi approx..... in PSIg (gauge) atmospheric pressure is zero and a perfect vacuum is -14.696PSIg or 30 in of mercury, iHg........ Kilopascals is the metric version of the absolute measure where a perfect vacuum is zero and atmospheric pressure is 101.325 kPa........
the MAP value represents engine load and a higher number represents higher load (more open throttle compared to RPM).......
example :
cruising along at 3000rpm on a slight down grade has very low engine load and a lower kPa number..... if that slight downgrade turns into a steep uphill you open the throttle to maintain 3000 rpm and same speed and the kPa number starts to climb towards atmospheric pressure (101.3 kPa)
engines require more advance under load at a given rpm and also need more advance as rpm increase at a given load
any questions??
Ww
master wizard
RIP Mr Jimi
"All The Way"
Old 2nd April 2012
So how much advance do I need going uphill at 60 mph at 3000 rpm ?
Old 2nd April 2012
DaytonaSportster's Avatar
DaytonaSportster DaytonaSportster is offline
DaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond repute
I saw one of those at bike week, its a TC88a with an S$S sticker on it.
http://xlforum.net/forums/showthread.php?t=842245
Old 2nd April 2012
xena's Avatar
From the description, the IST doesn't sound
anything like the TC88A. Link
Sportsterpaul has one so he'd know more than us.
I'll ask him to stop in here and comment.
