0 How Indian Makes 43% More Power than Harley-Davidson
Last Post: XL1275
0 Air Filter / Fuel Filter on a 2005 XL1200C
Last Post: Jerico
0 Help! Clutch cable replacement
Last Post: Hellbent_4
0 WTD: XL1200S SE Ignition module
0 1981 Ironhead Dual disk question
0 What Carb
0 91 883 sporty died while riding, will not crank.
0 New sportster in HD Research Survey
0 Ironhead 1984 trouble shooting
0 Sportster Seat For Sale
Last Post: XM381
0 Fyi
Last Post: 1200CustomHD
0 80 sportster coil replacement ohms questions
Last Post: blk80bike
0 Points Assembly - Circuit Breaker Cam and Alignment Pins
Last Post: jbradley46
0 Help with oil pump drive gear
0 XLFORUM quit smoking thread
Last Post: XL1275
0 Replace sprocket
0 My 900: half-H, half-CH
Last Post: Parker 1000
0 stumble
0 FAF Sporties
Last Post: Smokin Sam
Last Post: bklyngeezer
0 1992 Sportster indicator module
0 Repainted my bike
Last Post: Samedward
0 My Cafe Build...2002 883R
0 Do people notice your bike?
Last Post: commando57
0 Removing transmission 1973 XLH
Last Post: Beary
irvingjr (72), 909XR (63), Ghost_FL (61), mark R (60), TWISTED (47), spade (45), Drivethis29 (40), dodgetrucken (35)
  #51
Old 26th December 2014
Ocgreenmachine's Avatar
Ocgreenmachine Ocgreenmachine is offline
Sportster/Buell Model: XB12Scg
Ocgreenmachine has much to be proud ofOcgreenmachine has much to be proud ofOcgreenmachine has much to be proud ofOcgreenmachine has much to be proud ofOcgreenmachine has much to be proud ofOcgreenmachine has much to be proud ofOcgreenmachine has much to be proud ofOcgreenmachine has much to be proud ofOcgreenmachine has much to be proud ofOcgreenmachine has much to be proud ofOcgreenmachine has much to be proud of
Have you guys dynoed the bike? Curious how the pipe performs.
2009 Buell XB12S w/Hammer Performance 1250 kit. Dean Adams RT-XB1 exhaust, Custom ECM.
Redbeard2's Avatar
Redbeard2 Redbeard2 is offline
Sportster/Buell Model: M2 Cyclone
Other Motorcycle Model: Suzuki GSF1200S Bandit
Other Motorcycle Year: 2002
Redbeard2 has much to be proud ofRedbeard2 has much to be proud ofRedbeard2 has much to be proud ofRedbeard2 has much to be proud ofRedbeard2 has much to be proud ofRedbeard2 has much to be proud ofRedbeard2 has much to be proud ofRedbeard2 has much to be proud ofRedbeard2 has much to be proud ofRedbeard2 has much to be proud ofRedbeard2 has much to be proud of
Burly:
What sized tires did you run on your project bike? You've done real good on it!
Old 2nd January 2015
Kwas Kwas is offline
Sportster/Buell Model: XL
Sportster/Buell Year: 1986
Kwas is an unknown quantity at this point
Default Very Nice Build
I am currently starting to rebuild and redesign a 1986 Sporty. It was my father in laws first Harley and he got me into riding. I had a few sportys and a Vrod that I did a lot of work on. When my Father in Law passed away last year I bought this bike so I can keep it in the family. I don't really care for the cruiser style so the cafe style is perfect for me. I love the bike you built and plan on using portions of it as inspiration on how I want the bike to look. Gotta get those shocks first thing. I plan on building it with my sons to eventually hand down to them.
Old 16th May 2015
THEREALONEONLYBONZO THEREALONEONLYBONZO is offline
Sportster/Buell Model: XL1200/Traded/
Sportster/Buell Model #2: Coming soon Superlow
Sportster/Buell Year #2: 2011
THEREALONEONLYBONZO has disabled reputation
I'm curious about that Speed Merchant Triple tree. Did that tighten the rake up or shorten the wheelbase at all?
Old 16th May 2015
Redbeard2's Avatar
Default Aftermarket Triple Trees
Normally unless rake is built into the triple trees such as on a V-Rod they do not change the rake. If you shorten the front forks or raise the rear end with longer shocks it will tend to decrease the bike's turning radius and let it turn quicker on the twisties. You are in effect decreasing the bike's rake slightly [without welding on the steering head].
Old 17th May 2015
Redbeard2's Avatar
Default Rake and wheelbase
An afterthought: Decreasing your rake [by welding and changing your steering head angle] also makes for a shorter wheelbase which also quickens the handling. The reason why Sporties handle so much better then Big Twins is because of their shorter wheelbase and considerably lighter weight! Most Sporties come stock with a wheelbase around 60 inches.
Old 10th August 2017
Blackbenny Blackbenny is offline
Sportster/Buell Model: Iron 883/1250
Sportster/Buell Year: 2015
Sportster/Buell Model #2: 48
Sportster/Buell Year #2: 2016
Blackbenny is an unknown quantity at this point
Originally Posted by Burly Brand View Post
Balance of the covers went to powder and body to the painter. Now we pray.
In the meantime we're going to get a little ghetto style. Picked up a couple cans of Harley's "texture black" (the most expensive rattle can we've ever purchased!) and tested against the powdered parts. Dead match. That cinched it, we're not pulling the motor. We are now masking gods.
And this came in the mail:
Loves us some Biltwell stuff. Blacking out the motor made the carb cap and ignition cover almost mandatory.
http://www.biltwellinc.com/
Motor should be dry and ready for assembly soon.
Fresh set of Burly Clubmans get unwrapped. Internal wiring on this style of bar has always been a nightmare so we capped the ends. Now you can work the wiring though the hard corners. Makes it a ton easier to wire them. Obviously stock length wires are plenty good, so pulling the wiring out of the connectors, feeding it through the bar and reinserting it into the connector takes minimal time.
Picked up an Speed Merchant triple tree, too. These things are a work of art. http://thespeedmerchant.net/
It got tossed into the freezer for a little metallurgy lesson (wife not stoked). As it turned out the bearing fitment was not as tight as the factory stuff and it probably did not need to spend theday with frozen pees, but better safe than sorry (ummm, sorry hon).
I'm having the same problem with loose trees with the speed merchant ones. how did you fix this? the pics no longer show.
