Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Transmission, Clutch, Primary & Secondary Drive
Last Post: 83XLX
0 Carburetor opinions
0 ***DK Custom Products Outlaw Permanent HiFlow Reusable Oil Filter***
0 Are 2003-prior cams and cover a bolt-on swap?
Last Post: farmall
0 1960 XLCH in the UK
0 hot start and starter "coughs"
Last Post: clnsflknr
0 Clutch cable deal
0 C&C Solo Seat comfort?
0 Fuel Injection cleaner
Last Post: farmall
12 air leak from intake
0 A Day in the Life...
0 570's or 536, 560's @10:1 Compression
0 When Were You Born?
Last Post: Joe_jeep
Last Post: Wilkinson949
0 crank case breather
0 40mm CV vs. S&S Super E for Draw thought Turbo!
Last Post: MonkeyMadness
0 Bike sold leaving forum
Last Post: 11alan111
0 *DK Custom - M8 Softail Passenger Pegs - Now You Have Options - Intro Savings*
0 Ride Report for the 2019 Void rally
Last Post: Coop802
0 My new LED headlight
Old 12th January 2014
islanddave islanddave is offline
Sportster/Buell Model: sportster 883
islanddave is an unknown quantity at this point
Default Chain Conversion Kit
Hello,
Now that I have my engine out of the frame I would like to convert it over to chain drive. I do not want to have to pull the engine to change a belt. Can someone recommend a conversion kit?
Thanks Dave
rejeanprimeau's Avatar
Originally Posted by islanddave View Post
Hello,
Thanks Dave
On a sportster you don't have to pull the engine out, just the right shock absorber. ????
This is a Buell M2.....the engine needs to come out.....or the very least the rear isolators need to be removed.
So anyone with experience with a chain conversion for a Buell?
Old 19th September 2014
gusm2's Avatar
gusm2 gusm2 is offline
Sportster/Buell Model: Cyclone M2
Other Motorcycle Model: Suzuki SV650
Other Motorcycle Year: 01
gusm2 is an unknown quantity at this point
Default Belt Change
A lot of folks poo poo the chain conversion as the rear wheel has no cush drive fitted and is considered too harsh on the output shaft bearings for road use,
I am interested in making the change over also but only that I want to fit a longer swinging arm to drag race and the belt is no longer an option,
there is a tool which I bought from a company in the states that allows you to replace the belt with very little strip down, I can't remember the company but it was recomended to me by Al at ASB I'm sure he'd let you know if you call him.
Or see this below the same principle just a different way of compresing the isolator
http://danielcstarr-pages.blogspot.c...nique-for.html
Hope this helps
Ireeman's Avatar
Ireeman Ireeman is offline
Asgardian
Sportster/Buell Model: 883r
Other Motorcycle Year: abov
Wandur has dealt with offset counter and wheel sprockets...get up with him.
Old 24th March 2016
wlcastledine's Avatar
wlcastledine wlcastledine is offline
Sportster/Buell Model: Buell X1 Lightning
wlcastledine is an unknown quantity at this point
American Sportsbike has s chain conversion kit that I am thinking of trying:
http://americansportbike.com/newdir/Item/A16002
Sent from my R7g using Tapatalk
Old 24th March 2016
Bob F's Avatar
Bob F Bob F is offline
XLF LIFEMEMBER Im retired
Why a chain?
I have over 70,000 miles on my Eglide belt and it still looks new.
