0 Generator light q
0 S&S Super E Carb
Last Post: jp2code
0 Xl???
Last Post: 1200CustomHD
0 New to me 55kh
Last Post: thecarfarmer
Last Post: BigMek
0 Need Tuning Advice 1275 Kit 560 Cams
Last Post: XL1275
Last Post: Nitro57xl
0 so it's officially ended
Last Post: soundnav
0 is a buell a harley
0 Nup 1009 (Bearing)
0 The Sport(ster)ing Life
Last Post: Skeezix
0 Round Air Cleaner Poll
Last Post: Joe_jeep
Last Post: 77IRHD
0 Finnish custom rider
Last Post: FinnDRZ
0 AGM battery for 76' XLH
Last Post: JonesL
Old 13th August 2009
themilkmaan's Avatar
themilkmaan themilkmaan is offline
Sportster/Buell Model: sportster 1200 upgrade
Sportster/Buell Year: 1986
themilkmaan is an unknown quantity at this point
update guys i did find a short by the ignition housing, so i tore it all apart ound a red wire in 2 so i reconected it and no change in the clicking, but when i move the wire a certain way no clicking, so i need to find the short, but still this doesn't solve the clicking issue? uummm i shit sucks asssssssssssssssss........
Old 14th August 2009
well fellas thanks for your time it looks as though my starter i got 6 months ago is bad, for all the work i did tearing it apart i did find a short in the wire and fixed it.. thanks again for all your sugestions and help.. l8r dayz
aaron
the milkmaan
DogBunny's Avatar
DogBunny DogBunny is offline
Sportster/Buell Model: XLH883-1200 Ol Black Mare
Sportster/Buell Year: 1990
Sportster/Buell Model #2: Yam. XS650 "Angry Hornet"
Sportster/Buell Year #2: 1979
Other Motorcycle Model: Yam. XS650 "Bug Killer"
Other Motorcycle Year: 1976
DogBunny is a splendid one to beholdDogBunny is a splendid one to beholdDogBunny is a splendid one to beholdDogBunny is a splendid one to beholdDogBunny is a splendid one to beholdDogBunny is a splendid one to beholdDogBunny is a splendid one to beholdDogBunny is a splendid one to beholdDogBunny is a splendid one to beholdDogBunny is a splendid one to beholdDogBunny is a splendid one to behold
Thanks for the update, glad you got it fixed.
Arwalkz007 Arwalkz007 is offline
Arwalkz007 is on a distinguished roadArwalkz007 is on a distinguished road
I had a starter relay go on the 07 nightster. It was clicking when I would try and start the bike, no other sound, just lights. replaced it and it was all good, it was like 8 bucks at the dealership.
Old 15th August 2009
hey guys im back im narrowing the issue, i thinks it is now somewhere between the relay siwtch and the starter, my starter is good, the wires coming from my bars are good no break in the wire, use my volt meter to make sure. so now i just have to figure out which wire is bad, any idea's on what to check? im not really good with electircal crap so any pic's would be gr8t.. thanks fellas
the milkmaan
Old 2nd October 2009
northeast eric's Avatar
northeast eric northeast eric is offline
Sportster/Buell Year: 1987
Sportster/Buell Model #2: ironhead
Sportster/Buell Year #2: 78
northeast eric is an unknown quantity at this point
Originally Posted by 72Iron View Post
In my experience, if the relay is clicking then it's working, it's when relays don't click then they are suspect.
well if it is your solenoid then these pics can pretty much explain what you are in for. i ordered a new relay and solenoid rebuild kit off of ebay for $26 with shipping. i was hoping the new relay would fire the starter up... nope, still clicking. so i went ahead a took off my starter, opened it up and noticed the contacts were knurled. these pics were from today, i'm hoping someone can use these as some form of help. i'm halfway through this so i will post the rst of the pics tommorow.
you can click on the pics for a larger view.
starter unbolts through the primary chamber.
remove front sprocket cover and pull starter off the right side.
contacts are seriously busted.
after i rebuilt the contacts.
STAY TUNED.
www.northeasteric.blogspot.com
Bully's Avatar
Bully Bully is offline
Sportster/Buell Model: CUSTOM 90"
Bully has a spectacular aura aboutBully has a spectacular aura aboutBully has a spectacular aura aboutBully has a spectacular aura aboutBully has a spectacular aura aboutBully has a spectacular aura aboutBully has a spectacular aura aboutBully has a spectacular aura aboutBully has a spectacular aura aboutBully has a spectacular aura about
i would just replace the starter relay for starters. They are only a few bucks at an autoparts store. Usually you can feel the silenoid click if it is that and not the relay. Place your hand on the starter and hit the starter button if you feel the click on the starter it is the silenoid if not its the relay.
thanks partner i just sent the starter back it was only 6months old, not even. it was under warratny, there was no reason why the contacts were all rusted, but thanks.
ride safe and alil warmer these dayz
the milkmaan
Old 7th October 2009
the junk they make now days can still click but not work. they are cheaply made as a couple of post showed some photos of such.
the contacts can burn creating a resistance to current flow and corrode as some stupid put copper and iron together which are dissimilar metal and will adversely react when together. the problem can be the same in the solenoid on the starter. taiwanese ted junk!!!!
Cool Bot Ir Done
thanks got it all worked out? enjoy your halloween.. HEHEHHEHEHH l8r
