0 manifold leaks
Last Post: hbsporty
0 Bike sold leaving forum
Last Post: A Seabee
0 DK Custom Bullet Visor Style Halogen Headlight Relocation Kits
0 It’s Glamazon’s Birthday!
Last Post: BSA Bob
0 Hammer / Axtell cylinder weights?
Last Post: rubine
10 how low do you let it idle
Last Post: csmith72
0 Headlight Temps with 55/60W bulb?
0 Brand new Golan petcock issue
0 Digital speedometer
Last Post: csmith72
0 1960 XLCH in the UK
0 DK Custom Billet Tank Lifts - New Sizes & Finish - Q&A
0 crank case breather
0 Shocks on CL for Ironhead?
Last Post: Whitewalls
0 stress killer
0 570's or 536, 560's @10:1 Compression
Last Post: Turbo Sporty 48
Last Post: Joe_jeep
0 *DK Custom - M8 Softail Passenger Pegs - Now You Have Options - Intro Savings*
Old 1st October 2009
RobEvans RobEvans is offline
Sportster/Buell Model: 1200N
Sportster/Buell Model #2: Ironhead
Sportster/Buell Year #2: 1977
RobEvans has a spectacular aura aboutRobEvans has a spectacular aura aboutRobEvans has a spectacular aura aboutRobEvans has a spectacular aura aboutRobEvans has a spectacular aura aboutRobEvans has a spectacular aura aboutRobEvans has a spectacular aura aboutRobEvans has a spectacular aura aboutRobEvans has a spectacular aura aboutRobEvans has a spectacular aura about
Default The minimalist Sissy Bar
So... I've been searching EVERYWHERE for a decent sissy bar that's removable. I hate the ones harley makes so I designed and made my own. I wanted something that I could put on and take off easily since most of the time I don't need it. And I wanted to be able to have different styles for carrying stuff or just a low grab rail so my chick doesn't feel like she's going to slip off the back fender. I designed the side brackets and had a machine shop make them. I "eyeballed" the 1/2 inch sissy bar and hand bent it with some map gas and elbow grease. Ideally everything would be powder coated but it's just rattle can gloss. Then I put a screw in each bracket to hold it in place. I haven't "fully" tested it but it's a lot more solid than I thought. It doesn't flex much at all when I lean on it.
Anyhow... let me know what you think.
gomorley's Avatar
gomorley gomorley is offline
Sportster/Buell Model: 1200Custom
gomorley has a brilliant futuregomorley has a brilliant futuregomorley has a brilliant futuregomorley has a brilliant futuregomorley has a brilliant futuregomorley has a brilliant futuregomorley has a brilliant futuregomorley has a brilliant futuregomorley has a brilliant futuregomorley has a brilliant futuregomorley has a brilliant future
The pics don't show.
I'm a bad, bad TROLL....
Weird... they did before... let me see what I can do.
How about now... maybe they're too big?
gomorley's Avatar
That's better
Banned
So where does this 'chick' of yours perch?
And yes, it looks well made, just not sure about a couple of screws holding it down???
K3vl4r's Avatar
K3vl4r K3vl4r is offline
Other Motorcycle Model: Yamaha XS 750 E
Other Motorcycle Year: 1978
K3vl4r is just really niceK3vl4r is just really niceK3vl4r is just really niceK3vl4r is just really niceK3vl4r is just really niceK3vl4r is just really niceK3vl4r is just really niceK3vl4r is just really niceK3vl4r is just really niceK3vl4r is just really niceK3vl4r is just really nice
I dig it. Want to make a few more?
Kwest187's Avatar
Kwest187 Kwest187 is offline
Sportster/Buell Model: 883/1200 standard XL
Sportster/Buell Year: MUTT
Kwest187 is just really niceKwest187 is just really niceKwest187 is just really niceKwest187 is just really niceKwest187 is just really niceKwest187 is just really niceKwest187 is just really niceKwest187 is just really niceKwest187 is just really niceKwest187 is just really niceKwest187 is just really nice
Looks great we must be on the same wave length-
Here's mine I fabbed together last Sat.
still need to grind down welds and paint...but the seat and sissy bar are separate and will slide into frame using set screws (bolts) so can either go sissy bar only, seat and sissy bar or none of the above-
Did you weld your sliders right to your fender struts?
looks good I like it-
The horizon will never come into focus-but that doesn't keep me from trying.
Thanks. Yeah... the "tube" part of the "brackets" are custom ordered to have a tight tolerance with the 1/2 inch bar... the brackets are actually bolted in (using the existing bolts) so there's no damage to the bike. Then the "tube" is drilled... tapped for a screw and the sissy bar is drilled through... so the screws go through it to hold it in (not on it if that's what you were thinking). It could be held with a sturdy cotter pin but I figured the screw would be better. As far as making more goes... if I can figure a way to get the price down I'd be all about it.
Old 2nd October 2009
rabidchimp rabidchimp is offline
Sportster/Buell Year: 97
rabidchimp will become famous soon enoughrabidchimp will become famous soon enoughrabidchimp will become famous soon enoughrabidchimp will become famous soon enoughrabidchimp will become famous soon enoughrabidchimp will become famous soon enoughrabidchimp will become famous soon enoughrabidchimp will become famous soon enough
Nice work, Rob. Clean, simple.
-Aaron
Stairman for President 2012, 2016, 2020 etc.
