5 Favourite grips?
0 It's Glamazon's Birthday!
Last Post: clark1124
0 Big bore Stroker problem
Last Post: thefrenchowl
0 One More Ohio Meet & Eat?
Last Post: toe
2 My 1275 Hammer Conversion..
0 Oil leak
0 Done for now (no really)
Last Post: Pagey
0 Any Teamsters?
0 Bike wobble question
Last Post: semjpm
0 Any wealthy forum members?
0 2007 883R Roadster seat / tank & 2014 + slip ons
Last Post: jac737
0 Black drivetrain models?
0 stumble
Last Post: randy3934
0 Gear Spacing Question
0 New oil tank
0 Fyi
Last Post: salmanmr
Old 6th July 2010
Sbobber's Avatar
Sbobber Sbobber is offline
Sportster/Buell Model: Xl low
Sportster/Buell Year: 09
Sbobber has a spectacular aura aboutSbobber has a spectacular aura aboutSbobber has a spectacular aura aboutSbobber has a spectacular aura aboutSbobber has a spectacular aura aboutSbobber has a spectacular aura aboutSbobber has a spectacular aura aboutSbobber has a spectacular aura aboutSbobber has a spectacular aura about
And one more question can i just leave the connections open like that??
Old 6th July 2010
Cosmo Kramer's Avatar
Sportster/Buell Model: 1200N
Originally Posted by Sbobber View Post
Thanks man just did my headlight and clutch wire.. works like a charm and no speedo it is. thanks to u my bars are clear and my bike is actually running cuz i could not figure it out. It took me like 5 min to do all that and before u had told me i was already working on my bike for 5 weeks and couldn't figure it out. again thanks man i might be bothering u a little more in the future haha
Cool!...glad to help. No bother...feel free to ask me any questions in the....oh wait...you already did!
Not sure what connections you left open? You still have the connector plugged into the TSM correct so that your turn signals work and all that jazz? Did you cut the #9 and #12 position wires and connect them together?....thus leaving you with the #9 & #12 positions pigtailed off the connector? If that is the case....then you just cover them so they don't touch anything. A trick we used for military enclosures was to take the end of the loose wire, bend it back over itself about 1/2" and then shrink wrap that. If this is not what you mean....just let me know.
Cosmo
Old 6th July 2010
Sbobber's Avatar
No sorry i needed to be more detailed in my question. I did not mess with the tsm but i did have a secutity system and i used your thread on tssm to tsm swap. great help by the way i love the tsm so much more than that piece of s**t ... ok sorry back on subject.. i meant the speedo and front turn signal male plugs. thanks
Old 6th July 2010
Sbobber's Avatar
By the way i have no turn signals and no horn and no high beam lights... so i removed all the wires from the bars and relocated on off switch and start on side cover. came out great just need to put my seat and fender and my baby is all done.. thanks again
Old 7th July 2010
If it was me....I would keep your speedo connector available so that you can plug it back in and read diagnostic codes in the future if you start having problems with the bike. I would put some dielectric grease into each of the terminal positions on the connector and then wrap it in electrical tape to help keep the moisture out.
IF you have no intentions on ever going back to the stock controls set-up on your bike...if it was me I would cut the connectors off for the left/right side....stagger the cuts so no two wires have the ability to touch eachother and shrink wrap the bundle to keep the elements out. Or if you want to keep them....if I remember right those two connectors are somewhat cylindrical in shape....so you could get a plastic plug cover and then some large heat shrink tube. Slide the cover over the open end and then the heat shrink tube to keep it on and better seal it. Home Depot / Lowes carries the larger heat shrink tubing and you could probably find the plug end cover there too.
Just some ideas.
Old 7th July 2010
Sbobber's Avatar
thanks a lot i will keep the speedo and the connections i dont want to do too much to the wire harness i case i do change my mind later on..... I think i will do the cover and shrink wrap thing i think that is an excellent idea again thanks great help on everything
Old 7th July 2010
No problem SB....glad I could help.
Hey...do us a favor and let us know where you find the material. Like I said...I have seen the large diameter heat shrink in Lowes / Home Depot....but the plastic caps will take a little digging to find. Might be some in those bins in the hardware aisle.
Old 8th July 2010
Sbobber's Avatar
no prob ill keep yall posted on everything and ill take some pics also.
Old 31st July 2010
Just want to add that if you bypass the TSM you will have diagnostic trouble codes present 100% of the time and if you are still using the stock speedo the check engine light will be on all the time also.
I just bypassed my TSM and put 50 miles on the bike to test it and the only two codes I got were expected:
P1010 - Missing password (ECM is looking for the TSM)
U1255 - Serial data error/missing (again, TSM is missing)
The bike ran fine without any issues starting.
Old 22nd August 2010
NO COAST CHOPPER's Avatar
NO COAST CHOPPER NO COAST CHOPPER is offline
Other Motorcycle Model: Vespa Sprint
Other Motorcycle Year: 1974
NO COAST CHOPPER will become famous soon enoughNO COAST CHOPPER will become famous soon enoughNO COAST CHOPPER will become famous soon enoughNO COAST CHOPPER will become famous soon enoughNO COAST CHOPPER will become famous soon enoughNO COAST CHOPPER will become famous soon enoughNO COAST CHOPPER will become famous soon enough
Awesome. This is just what I needed. I have security on mine, so does the dealer have to put the ECM or the TSM in service mode?
