0 Finding a new doctor...
0 Flat Tire
Last Post: denguy
0 1968 xlch
Last Post: denguy
0 Motorcycle Events
Last Post: rhartlin
0 Bendix / Zenith questions
Last Post: hawgford
5 What's Your Temp Today
Last Post: Kbetts
0 C&C Seat Decision
0 1200 kit coversion with 50k miles?
Last Post: Blue Scoot
0 Stock Straight Rate Fork Spring Weight on Rubbermount 1200C
0 Arbor press for crankshaft
0 So heres the plan
Last Post: Bryan1976
0 compression problems
Last Post: oupa
0 Dyno Run, V&H straight shots vs. Screamin' Eagles
0 Forum problems???
Last Post: bplinson
Last Post: moparnut72
10 What's your Personal Tech
0 ultima iggy,, static time vs dynamic time
0 Seized Oil Pump
0 Hello from Seattle
Last Post: racemoto
0 my build in my apartment
Old 4th June 2018
883openpipes 883openpipes is offline
Sportster/Buell Model: 883
883openpipes is just really nice883openpipes is just really nice883openpipes is just really nice883openpipes is just really nice883openpipes is just really nice883openpipes is just really nice883openpipes is just really nice883openpipes is just really nice883openpipes is just really nice883openpipes is just really nice883openpipes is just really nice
Default Dyna s sportster timing
Hi,
883 1999
Can someone share a picture of their dyna s mounted ? This way I know if my dyna is in somewhat the correct position. Currently I am on my holiday address with my bike and I dont have a timing light nor tools to check the tdc location.
It runs very good and starts perfect but I would like to check it to be sure at least I dont burn holes in my pistons in this hot environment.
Next time I go here I will bring the necessary tools with me.
Thanks.
Old 4th June 2018
How did you set the timing when you installed it? BE SPECIFIC!
2 Relax
Old 4th June 2018
I put the pickup at three o clock
Old 12th July 2018
It still runs.. Have driven 1000 miles with it now, should be a safe timing I guess ?
Old 12th July 2018
1999 Model - Did you revert to using a mechanical advance? The Dyna S is just a pickup coil (essentially, electronic points)...
Or do you have some other model Dyna ignition?
2 Relax
Old 12th July 2018
Yep.. Mechanical advance!
Old 13th July 2018
Here's the Sportsterpedia REF section on the Dyna-S:
http://sportsterpedia.com/doku.php/t...ngctl01#dyna_s
There are install instructions there along with Static Timing info...
Is it the Dual-Fire version (DS6-1) or the Single-Fire version (DS6-2)?
2 Relax
