0 Frame mods
Last Post: farmall
0 Might as well join I guess...
0 '71 XLCH owner in Roanoke, VA
0 "S" model specific Q&A
Last Post: Tomt
14 Where do you store your Sportster over the winter?
Last Post: r4fthrs
0 07 heads on 04 rubbermount
Last Post: hbsporty
0 Engine breather 101 / Crankcase vent 101
Last Post: 83XLX
Last Post: Condor
0 Suzuki Lights On 883
0 Replacing Front brake switch
0 October 13th - Ironhead Rider Gathering: PA/NJ (Fall 2018 G.B.B.)
Last Post: thefrenchowl
0 New Freewheeler On The Way
Last Post: debster
0 2019 Suzuki Katana
0 Another spark plug question...
0 Show your bike next to a lake
0 Electrical problem - won't start, infamous solo click
0 Occasionally pops out of 2nd
0 I have a problem with my sportster. (Intermittent Starting Problem)
0 INNOVV K2 motorcycle DVR
Last Post: Ocgreenmachine
0 Another ironhead roadracer
Last Post: mrmom9r
Last Post: SLW210
0 Hello From San Diego
Last Post: hoggy
0 Hello xlforum
Last Post: hoggy
0 Hello from Clarksville, TN
Last Post: hoggy
jackson91 (49), TheLAW (43), tat2cj, C_Ranger (29), XL Kenny (26)
Old 11th July 2018
kmul kmul is offline
Sportster/Buell Model: xlx
Sportster/Buell Year: 1983
Sportster/Buell Model #2: XLH
Other Motorcycle Model: FLHR, BD Vintage, 59 XLH
Other Motorcycle Year: 1998
kmul is a splendid one to beholdkmul is a splendid one to beholdkmul is a splendid one to beholdkmul is a splendid one to beholdkmul is a splendid one to beholdkmul is a splendid one to beholdkmul is a splendid one to beholdkmul is a splendid one to beholdkmul is a splendid one to beholdkmul is a splendid one to beholdkmul is a splendid one to behold
toejam, yeah I knew something was loose as I could feel it in rear like swingarm engine mount area and got around to it finally. one bolt loose frame to motor mount. helped. hopper, yes I had some old rubber ones I put in and ordered some new ones. came in package that said rubber but sure felt like urethane. couldn't sink my thumbnail into it at all. right now I have the softer of my urethanes on top and a worn out rubber on the bottom. I will try j&p to see if their advertised rubber ones are really rubber. what I did do was drive a freeze plug into handlebar till where it indents for switch wires each side. then filled it with lead picked from rifle range. shot would have been better but next time. I put sand in to fill voids and tapped it to settle. capped bar end with another freeze plug. noticeable improvement. worth doing. 22 mm freeze plugs are perfect fit. 7/8 too big. 22 mm hard to find. you will have to order them somewhere. I had to buy a box of 25 on ebay.
