0 XLH 883 1987. Please advise. (Jetting And Air Filter)
Last Post: xlh883-1987
0 vibration problem solved - CHECK YOUR FRONT ENGINE MOUNT BOLT!!
Last Post: Bruce
0 My 1250 to 1275 build
Last Post: Bruce
0 Locked up rear wheel
Last Post: Darkseacret
0 25 April
0 Happy Birthday Decman!!!
Last Post: sltm1
0 Trans sprocket spacer is stuck
Last Post: xleddie
6 Calling all musicians
0 Been Sitting For 5-10 years; Starts, But Dies
Last Post: Feskerlars
Last Post: borada75xlch
7 Saying hello and getting acquainted!
Last Post: Flyboy25
0 My '08 short chop
Last Post: Dudepants
0 2004 rear mast cylinder
0 left him stranded
Last Post: davixlrtt
0 THE Hockey Thread
Last Post: Airbozo
6 73 Sportster Starts, Runs Fine, Dies
Last Post: Huginn
0 Evo sporty straw diagonal measurement... 883? 1200?
Last Post: ericfx1984
0 Gasket goo or not to goo
Last Post: Jollly Rogers
0 Rear rocker cover?
0 Resistor vs Copper plug wires?
0 77 xlh front end front vibration
0 Scored new to me used tins
0 BETTER Brakes for $214
0 First Startup after rebuild questions
Last Post: frogg_nutts
Durockrolly (61), xlch1973 (57), Rich_Alfredo (57), ehenry (55), 100thHugger (54), evobrian (52), jethrosurfs (47), Chris B. (43), Ebmomma (43)
Old 26th April 2018
DirtyHarry68's Avatar
DirtyHarry68 DirtyHarry68 is offline
Sportster/Buell Model: 1968
DirtyHarry68 has disabled reputation
Default ‘68 XLCH...transmission
Thought I’d start a new thread on this job, resulting from trying to fit a new clutch cable, ending up pulling the clutch due to noticing problems, ending up pulling the kicker...and now here we are. My shopping list is about 4 pages long.
No questions yet, but any advice welcome. Just intend to work through the FSM inspection routine next. In a couple of weeks and lots of reading I hope to understand vaguely how all these turny bits work together.
Al
Old 26th April 2018
brucstoudt brucstoudt is online now
brucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant future
i'm thinking this may have been covered in the clutch thread,but your clutch gear bearing should have a shield facing the kicker spring.an Andrews gear is always a welcome surprise.i bought my set about 6 years ago.they all have radius cuts at the corners of the dog pockets. how does the roll pin look above the mainshaft bearing race?
Old 27th April 2018
No, I don’t recall that being mentioned, thanks. I noticed the bearing had taken a beating, can only put this down to the spring
I wondered if that was an Andrews part number.
Roll pin looks good, at a glance.
Al
Old 27th April 2018
doodah man's Avatar
in your "shift tower" you have the early style pawl carrier assembly, the pins are known to stick in their bores. worth dismantling and cleaning really well, along with cleaning any/all crud off of the other parts and inside the trans cavity. it's dirt/gunk that causes them to stick. look closely (with a magnifying glass) at the pockets of main 3rd and counter 2nd - the infamous 20t gears - for any small cracks or fissures. it's these gears more than the others that destroy precious engine cases. with the trans assembled on the bench or even better in a vice, spin the clutch gear and shift through the gears and watch how it all works together. really that's the first step to understanding the transmission, plus it's neat to watch. any other andrews gears in there? a good thread to read through now that you have it apart...
http://xlforum.net/forums/showthread.php?t=1734747
Old 27th April 2018
chevelle's Avatar
chevelle chevelle is offline
Sportster/Buell Year: 19**
Sportster/Buell Year #2: 1965
Did you happen to check shaft end play on c/s & m/s?
Is that why the oiler plug was removed from trapdoor?
Or was the plug missing?
Everything Doodah mentioned is a good start.
Old 27th April 2018
doodah man's Avatar
his oiler plug is mia according to his other, recent clutch thread.
Old 27th April 2018
barefoot barefoot is offline
Senior Bike Builder
Sportster/Buell Model: XR 750
Sportster/Buell Year: 1972
Sportster/Buell Model #2: RR 250
Sportster/Buell Year #2: 1976
barefoot has a reputation beyond reputebarefoot has a reputation beyond reputebarefoot has a reputation beyond reputebarefoot has a reputation beyond reputebarefoot has a reputation beyond reputebarefoot has a reputation beyond reputebarefoot has a reputation beyond reputebarefoot has a reputation beyond reputebarefoot has a reputation beyond reputebarefoot has a reputation beyond reputebarefoot has a reputation beyond repute
Teeth look pretty decent. I see the crappy HD factory finish on some of them still hasn't smoothed out
edit: Just looked at your phtoos and ditched my treatise on the dogs. Yours look good. A little attention to detail on reassambly and your box oughta be a good one.
I'd take the blowup gears in and have them magnafluxed tho. I could be way out of date but that used to be easy and cheap. My eyes they ain't what they used to be, I'd probably miss a crack as big as the grand canyon doing just the visual check. I'd probaly mag the shift stuff, too. I know, that never breaks, no one has ever heard of it but a friend had the damn shift plate weld go bad on him once. There's nothing like being fifty-eight miles from home and can't get it into gear to make your day. Sporties are light on their feet but heavy to push.
All new bearings never hurts and that's pretty cheap, too.
Maybe do a quick doodah-check and make sure the trough in the roof that leads oil to the bearing isn't compromised. Another one-inna-million occurrence but if you are the one, it's unpleasant.
Old 27th April 2018
needspeed has a brilliant futureneedspeed has a brilliant futureneedspeed has a brilliant futureneedspeed has a brilliant futureneedspeed has a brilliant futureneedspeed has a brilliant futureneedspeed has a brilliant futureneedspeed has a brilliant futureneedspeed has a brilliant futureneedspeed has a brilliant futureneedspeed has a brilliant future
.......an Andrews gear is always a welcome surprise.i bought my set about 6 years ago.they all have radius cuts at the corners of the dog pockets.....
That's an interesting point about the Andrews dog pockets. The pockets on the latest ones have flat bottoms and radiused corners as Bruce noted. The one pictured here has been cut a lot like the way harley gears are made, with a large radius cutter.
Not saying that's bad. Just noting the difference. Maybe this is a very old Andrews gear.
Old 27th April 2018
Thanks, I’ll do all that. Just working up the courage to take it all apart and get it back together the way it’s supposed to be. I’m printing that thread to go through.
Main shaft .0015/6”, forgot to do countershaft, oops. Oiler plug is on shopping list.
Might be lucky and have 20T Andrews gears already, will check when I have it apart.
Thanks for the input so far.
Al
Old 27th April 2018
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
Iron Mike has much to be proud ofIron Mike has much to be proud ofIron Mike has much to be proud ofIron Mike has much to be proud ofIron Mike has much to be proud ofIron Mike has much to be proud ofIron Mike has much to be proud ofIron Mike has much to be proud ofIron Mike has much to be proud ofIron Mike has much to be proud ofIron Mike has much to be proud of
"Main shaft .0015/6”, forgot to do countershaft, oops"
From the pics, that c/s bearing surfaces look wasted. also appears perhaps a crack stemming from the cam plate hole in the tower. could just be the pics.
