Backfire
24th November 2022
Posts: 1,147 Sportster/Buell Model: xlh Sportster/Buell Year: 1975 Sportster/Buell Model #2: 84 xl paughco rigid Other Motorcycle Model: 70 xlch
Sifton 207's
In need of a sifton #3 barracuda (207) cam would buy a pair of intakes if someone had some thanks
11th December 2022
Posts: 1,276 Sportster/Buell Model: XLX Sportster/Buell Year: 83 Sportster/Buell Model #2: '85 ironhead drag racer Sportster/Buell Year #2: xlh
seill lookin for a first gear to match my andrews 16 tooth first gear.also have a black brand new '81 rear fender with the stick on reflecters.200.00+shipping.i believe i still have the box it came in
25th December 2022
nuthin??????????wow
25th December 2022
Posts: 359 Sportster/Buell Model: xlch Sportster/Buell Year: 1972 Other Motorcycle Model: homebilt fxr Other Motorcycle Year: 80+
what is gear you need?
think i looked b4, but can again
if your lookin for 1cs, i dont have, mine was pretty worn, is in scrap bin
1ms i may have
pete
25th December 2022
Posts: 8,562 Sportster/Buell Model: XLB, XLCH, Sporton Sportster/Buell Year: 1962 Sportster/Buell Model #2: XLCH Sportster/Buell Year #2: 1966 Other Motorcycle Model: XLCH (Another one) Other Motorcycle Year: 1966
Sorry Dave, no 1st gear left. You might have to buy a new one.
25th December 2022
Posts: 1,895 Sportster/Buell Model: xlh Sportster/Buell Year: 1974
Shaky Dave, So you need the wide ratio mainshaft first that is part of the Andrews set 251010?
Stock ratio and Andrews wide ratio mains both have 27 teeth, but the wide ratio is larger. 3.145" vs 3.025". The wide ratio main 1st is stamped "2.68".
As you mentioned, Andrews sells the the wide ratio 1st as a set. It's no suprise that you're having a hard time finding someone that wants to give up just one of the gears out of a set.
4 Weeks Ago
trans is out and the 1st gears i built it with are stock ratio.ended up with the low ratio countershaft gear and needed the mainshaft gear but at this point i used the original cs gear and used a new andrews ms gear and its ready to go in.ahh wel thanks for lookin guys.its appreciated
