Backfire
5th October 2022
Posts: 9 Sportster/Buell Model: xlch Sportster/Buell Year: 1973 Sportster/Buell Model #2: XLH Sportster/Buell Year #2: 79 Other Motorcycle Model: HD FLTCUI Other Motorcycle Year: 96
connecting rod bearings
how often has anyone had to use undersize rollers ? doing the math i have -.00015 with a .001 clearance calculated in my gozintas . on the rear rod i had 1.6236 & 1.6237 ID of races, front race ID was 1.6245 . nos HD crankpin =1.2488. rollers are .1873. Am i doing my math right ?
5th October 2022
Posts: 2,729 Sportster/Buell Model: Xlh Sportster/Buell Year: 1959 Sportster/Buell Model #2: Sprint 350 Sportster/Buell Year #2: 1969 Other Motorcycle Model: Guzzi Ambassador Other Motorcycle Year: 1969
No.
Rather than fit undersized bearings -- you instead hone the races for clearance.
10th October 2022
thanks for the reply....i saw undersized rollers and was wondering about that. bought this early '73 as a basket ,literally brought it home in the trunk of my car. been a very slow process being able to dedicate myself to it. don't know any history of the bike but have matching #'s .had found excessive play in crank bearings so i tore it all down planning to replace all bearings, bushings, seals and whatever else needed replaced. thrust washers were worn,1 was grooved pretty bad.it had steel roller cages with bronze washers,it was a little tricky getting the correct ones ,2 different ones listed in parts manual .
10th October 2022
Posts: 15,880 Sportster/Buell Model: XLCH Sportster/Buell Year: 1960 Sportster/Buell Model #2: 883 C Sportster/Buell Year #2: '03
which is the best route for you? honing the races requires a precision tool,lapping or rigid honing.undersize rollers could be done at home? accurately i can't say.
10th October 2022
Posts: 972 Sportster/Buell Model: 883 Evo Sportster/Buell Year: 1989
Easiest: buy a rod & pin set outright, comes fitted with rollers and pin bushings
11th October 2022
Posts: 1,895 Sportster/Buell Model: xlh Sportster/Buell Year: 1974
Some questions.
Availability of undersize rod rollers? This is new to me. Where do you get them? I've heard of undersize plain bearings for a car but never harley roller bearings. They may exist, but never seen in Harley parts books. Just standard and over sizes.
Did the parts you measured in post 1 come from the engine you bought? If so and your measurements are accurate the rear rod was too tight, and yet you say there was excessive play in the crank bearings.
If you rebuild the rod bearings, the right way would be to lap or hone the races as mentioned in post 2 so they are true and round and fit new rollers.
Agreed. If the quality is good this would be the easy way.
11th October 2022
Posts: 5,054 Sportster/Buell Model: Ironhead XLH Sportster Sportster/Buell Year: 1978 Sportster/Buell Model #2: Ironhead XLT Sportster Sportster/Buell Year #2: 1977 Other Motorcycle Model: Honda CBX 1000 Other Motorcycle Year: 1979
Send the crank to Truett&Osborn for rebuilding.
11th October 2022
Posts: 3,313 Sportster/Buell Model: KHK Sportster/Buell Year: 1954 Sportster/Buell Model #2: 900cc XLB Sportster/Buell Year #2: 1967 Other Motorcycle Model: 1200cc XLRTT Other Motorcycle Year: 1966
Think about it a second and you'll know why undersized rollers don't exist..
They might (just might...) fit OK on the ID and OD with a thou or two play, but will certainly crowd themselves on the PCD and won't turn freely...
It's only with white bearings that one grounds the crank and not the rods...
Patrick
11th October 2022
You don’t need to own a rigid hone or buy a rod set to solve this one.
Easiest and cheapest is to go to an automotive rebuild shop and give the machinist a $50 and your target measurements. About 10 minutes per rod maximum and you’re done.
Honing a Harley race is no different than honing split connecting rods for plain bearings and completely within the skill set of anyone with basic training on a honing station. They don’t have to be a Harley or motorcycle mechanic.
Or you can spend several hundred to solve it the other ways.
Buckdancers choice.
11th October 2022
Posts: 3,007 Sportster/Buell Model: xlch Sportster/Buell Year: 1964 Sportster/Buell Model #2: XLCH IR EFI Sportster/Buell Year #2: 1971 Other Motorcycle Model: BMW K1200RS Other Motorcycle Year: 2001
Chuck is correct. A honing machine does not know it is sizing a HD rod. A well equipped hydraulic cylinder repair shop should have the equipment as well, if an auto shop is not convenient.
If you go for the second suggestion towards the few hundred dollar route, your almost to the cost of a used hone and mandrel for the job. Then you can do them yourself as well as your next project,.. and the next, ect ect.
