Keep & Kill
VP fuel
Last Post: hbkeith
Backfire
17th November 2022
Posts: 50 Sportster/Buell Model: xlh Sportster/Buell Year: 1972
crankshaft width ironhead
What should be the width of the crankshaft? I have a lot of clearance on the connecting rod. In the photos, the pin is still unscrewed.
18th November 2022
Posts: 972 Sportster/Buell Model: 883 Evo Sportster/Buell Year: 1989
18th November 2022
I mean it is not tightened with the correct torque. After tightening, it can have a smaller width.
18th November 2022
Posts: 9,386 Sportster/Buell Model: XLCH 1000 Sportster/Buell Year: 1977 Sportster/Buell Model #2: 75 motor in Norton frame. Other Motorcycle Model: 42WLA 45, Harton, Narley Other Motorcycle Year: 1942
You have to have the nuts tightened up to 150 ft lb and there should be .005 to .015" clearance between the rod end and the flywheel.
The wheels will come in some as you tighten the nuts up.
18th November 2022
Posts: 3,313 Sportster/Buell Model: KHK Sportster/Buell Year: 1954 Sportster/Buell Model #2: 900cc XLB Sportster/Buell Year #2: 1967 Other Motorcycle Model: 1200cc XLRTT Other Motorcycle Year: 1966
I measured 3 of my rear con rods' width, all between 1.490 and 1.492 which gives 8 to 10 thou less than 1"1/2.
By the time you tighten your crank nuts to the required torque, it should shrink your 1"533 width to 1"1/2 or there about...
Patrick
19th November 2022
Thanks for help. After tightening is still 0.9 mm of endplay. I checked on the new and the old pin. It's the same gap. I need extra thick washers. I wonder if wide crankshaft will fit into case without a problem. Modern motors with pressed pin require high accuracy. Repair manual always shows this value. Unfortunately not Harley. Probably that difference doesn't matter much. I recently repaired a ktm mx engine where 0.2mm washer caused crankshaft not rotate.
19th November 2022
Posts: 8,562 Sportster/Buell Model: XLB, XLCH, Sporton Sportster/Buell Year: 1962 Sportster/Buell Model #2: XLCH Sportster/Buell Year #2: 1966 Other Motorcycle Model: XLCH (Another one) Other Motorcycle Year: 1966
So, your at 0.035 " which is technically 0.020 " wide.
There are thrust washers on the flywheels and these may be worn. That would account for the extra width. If the se wheels came out of an engine and you replaced the big end bearing because it was shot/worn that would be a good explanation for worn thrust washers.
If that's the problem over all width won't be affected. That is, you won't have a problem when you check the crank end float.
19th November 2022
Posts: 1,895 Sportster/Buell Model: xlh Sportster/Buell Year: 1974
Originally Posted by daniel91
.. I wonder if wide crankshaft will fit into case without a problem. Modern motors with pressed pin require high accuracy. Repair manual always shows this value. Unfortunately not Harley. Probably that difference doesn't matter much. I recently repaired a ktm mx engine where 0.2mm washer caused crankshaft not rotate..
You should have no worries about fitting the crankshaft in the cases. The fit is not that precise. Comparing these old Harley flywheel assemblies to other engines and designs is just a cause for consternation.
The distance that the sprocket shaft is drawn into the taper in the left flywheel will also have an affect on the centering of the crank in the case. There's no specification in the manual for that. Just a torque value.
Are you rebuilding with the same rods and flywheels that came from a running engine?
20th November 2022
The flywheels and connecting rod come from different engines don't come from a running engine. That's why I wasn't sure if everything was ok. I'm preparing an emergency set of crankshaft and bearings. Once I rebuild my sportster crankshaft. I didn't think about it at the time. I know I could have done better. Now I have time and more knowledge. Old engines are full of surprises and details matter. Especially when you're trying to make something out of scrap metal.
20th November 2022
Posts: 3,006 Sportster/Buell Model: xlch Sportster/Buell Year: 1964 Sportster/Buell Model #2: XLCH IR EFI Sportster/Buell Year #2: 1971 Other Motorcycle Model: BMW K1200RS Other Motorcycle Year: 2001
“Running” engines do not necessarily contain components that are still in “service wear limits”.
Sounds like you have a handle on things, but be sure to measure all components involved.
