Tank Art
Last Post: joe s
2 Weeks Ago
Posts: 18 Sportster/Buell Model: XLH 1000 Ironhead Sportster/Buell Year: 1980 Other Motorcycle Model: Road King Classic Other Motorcycle Year: 2011
Oil seepage from acorn nut on Rocker Box
Hey guys, I have oil seeping out of two of my acorn nuts one on the front cylinder and one on the rear. I would like to replace the o-rings, but when I try to remove them, the hex side comes off and the acorn nut just spins.
Is there a trick to getting the acorn nut off to replace the o-rings?
2 Weeks Ago
Posts: 734 Sportster/Buell Model: sportster stroker xlch Sportster/Buell Year: 1970 Sportster/Buell Model #2: sportster xlh Sportster/Buell Year #2: 1973 Other Motorcycle Model: 99 inch sportster Other Motorcycle Year: 2003
You might try double nutting the shaft threads with a couple of thin (jam) nuts.
2 Weeks Ago
Posts: 51 Sportster/Buell Model: XL 1200 Sportster/Buell Year: 2000 Sportster/Buell Model #2: XL 1200 Sportster/Buell Year #2: 1993 Other Motorcycle Model: H-D FLH Other Motorcycle Year: 1980
Your terminology is hard to follow.
If you mean the plugs on the right side of the rocker box are tight in the shafts, and you are spinning the shafts loose in the nuts on the left side:
First, tight plugs are a common problem, because they seem to tighten in service.
Second, you need to anchor the shaft firmly in the rocker box. Holding the right side plug, torque the left side nut to 40 ft.lb., for the solid chrome nuts found on your '80. (The thinner, earlier locking nuts, the ones with the red lights, can only take about 30 ft.lb.)
Third, go to the right side plug and spin it off with a rattle gun. It's often the ONLY way to get those plugs loose. Replace the o-ring (I personally like the 11118 quad seal in that particular location) and replace the plug, just snugging it in place, no heavy hand needed.
Jim
2 Weeks Ago
Jim
I think I understand what you're saying, but it's not the right side that is stuck it's the acorn nut on left side that I need to replace the o-ring, the "Plugs" on the right side are coming out quite easily.
2 Weeks Ago
OK, when I first read your post, that's what I thought you meant, but the above post in answer to your first kind of muddied my understanding.
There are no o-rings on the left side, the seal is just the thin, soft steel washer under the nut.
To tighten the left side nut, remove the plug on the right side. Put a 3/8 steel ball (oil pump checkball) in the opening, and follow with a 1/2-20 bolt tightened on the ball. All of this clean, of course, since this is part of your oiling system. Holding the shaft still with that 1/2" bolt. torque the left side nut to 30 - 40 ft.lb. as I said earlier. A light shock to the 1/2" bolt will break it loose, and you can remove the ball with a magnet. Assemble o-ring and plug, and you are done.
Jim
2 Weeks Ago
Jim
Ok, I think I understand that. So there are just crush washers on the left side that seal it up?
2 Weeks Ago
Posts: 38 Sportster/Buell Model: xlh1000 Sportster/Buell Year: 1976
For the rocker shaft left side acorn nuts: Per FSM-M813 Service Bulletin the acorn nut torque is 15-20 foot pound.
There is a misprint in the 70-78 FSM 99484-78 where 60-65 foot pound torque is recommended.
2 Weeks Ago
It's a 7/16 thread. 15 - 20 ft.lb. is laughable for that nut, I don't care what the service manual says. I can pretty much guarantee you that no motor left the factory with those nuts at that torque value. If the OP's shafts are leaking, then for sure they are not tight.
Jim
2 Weeks Ago
Jim, the left nut seats a shoulder of the rocker shaft against pn 17451-57 spacer<hard washer> that seats against a mating shoulder in the rocker cover.
The left nut has nothing to do with compression of the o-ring that is under the right rocker shaft screw pn 17448-57 or 17448-71A <depending on model year>
2 Weeks Ago
Yes, but the OP's complaint is that the shafts are leaking on the left side, not at the o-rings. That was confusing to me at first as well.
Jim
