VP fuel
Last Post: hbkeith
Backfire
1 Week Ago
Posts: 1,276 Sportster/Buell Model: XLX Sportster/Buell Year: 83 Sportster/Buell Model #2: '85 ironhead drag racer Sportster/Buell Year #2: xlh
or it could be the rocker box gaskets to the head which usually leak more then the shft nuts.could be makin the shfts look like they are leakin.pullin the boxes and replacin all the gaskets is my way of doin this.and how much oil is this motor leakin?someday we may find out
1 Week Ago
Posts: 1,895 Sportster/Buell Model: xlh Sportster/Buell Year: 1974
The danger of using more torque than necessary on the left side nut is not the failure of the 7/16 threads. It's the possibility of cracking the hardened washer on the inside of the cover.
A shaft diameter of about .553" being drawn by the nut against a washer with a 7/16 hole leaves very little surface area to bear against the washer.
1 Week Ago
Posts: 723 Sportster/Buell Model: sportster stroker xlch Sportster/Buell Year: 1970 Sportster/Buell Model #2: sportster xlh Sportster/Buell Year #2: 1973 Other Motorcycle Model: 99 inch sportster Other Motorcycle Year: 2003
Originally Posted by JB in NC
Yes, but the OP's complaint is that the shafts are leaking on the left side, not at the o-rings. That was confusing to me at first as well.
Jim
Sorry for any confusion I created. I focused on the o ring replacement.
1 Week Ago
Posts: 18 Sportster/Buell Model: XLH 1000 Ironhead Sportster/Buell Year: 1980 Other Motorcycle Model: Road King Classic Other Motorcycle Year: 2011
It's not the Rocker Box gasket, I can see the oil stream from the acorn nut. I was thinking it was an o-ring, but it may be the washer that is leaking. I rebuilt the top end a few months back with all new gaskets and o-rings. I could have sworn there were o-rings on the left side, but I'm probably remembering wrong.
Maybe the washer didn't seat properly or I may have over tightened it.
1 Week Ago
Posts: 42 Sportster/Buell Model: XL 1200 Sportster/Buell Year: 2000 Sportster/Buell Model #2: XL 1200 Sportster/Buell Year #2: 1993 Other Motorcycle Model: H-D FLH Other Motorcycle Year: 1980
If the shafts are spinning, the nuts aren't tight enough. See my earlier posts.
I always put a little liquid teflon pipe thread sealer on the shaft threads when I rebuild these, to forestall oil seepage.
Jim
1 Week Ago
Jim
That's a good idea, I'll do that if I can get them off.
