Keep & Kill
VP fuel
Last Post: hbkeith
Backfire
1 Week Ago
Posts: 685 Sportster/Buell Model: custom Sportster/Buell Year: na
Originally Posted by 01rk
What ever the stock jets are is what is in there, new vm38.
I am 80 years old I don't plan on racing anywhere just want it to run ok
put the S & S back on, follow the guide and ur probs are over
1 Week Ago
Posts: 159 Sportster/Buell Model: XLH Sportster/Buell Year: 72 Sportster/Buell Model #2: XLCH Sportster/Buell Year #2: 71 Other Motorcycle Model: Five Harleys
I would say use the Mik, it's a great carb once you get it dialed in. The difficulty is there are a lot of variables, as sungod pointed out. You don't need a dyno, but you do need a methodical approach to tuning. S&S has that in their instructions, and so does Mikuni.
1 Week Ago
Posts: 972 Sportster/Buell Model: 883 Evo Sportster/Buell Year: 1989
Have a nice day
1 Week Ago
Posts: 8,562 Sportster/Buell Model: XLB, XLCH, Sporton Sportster/Buell Year: 1962 Sportster/Buell Model #2: XLCH Sportster/Buell Year #2: 1966 Other Motorcycle Model: XLCH (Another one) Other Motorcycle Year: 1966
VM38 is the model and size, and has nothing to do with a particular engine, state of tune, etc. It's been used on engines as small as 125cc and as large as 84".
Anyone who believes that has never seriously looked at air flow requirements for an engine.
Port velocity is directly tied to the capacity of the engine and size of the venturi of the carburetor. A 38mm carb is simply not suited to a 123cc or a 1,376 cc engine. It will not work worth a fart on either of them.
A VM38 tells you the venturi size is 38mm. A VM28 may well work on a 125 but a 38 is not going to.
It's not "Simple as a rock", all of the overlapping circuits are already built in. There are only 2 jets, why is that better?
Technically, no. The VM series having 5 circuits as opposed to the S&S's 3 means you can "fine tune" the VM much closer too perfect than you can an S&S.
But will you ?
Because most people simply don't. They just want a carb that will run "acceptably". They don't like "sags" bogs", coughing" or "pops".
IF, you know what your doing and if you spend the time and money to dial in a Mikuni it will perform marginally better than an S&S. Maybe.
I would love to see someone make a VM38 work on a 125cc engine. Maybe at 48,000 rpm ?
1 Week Ago
Posts: 583 Sportster/Buell Model: XLH Sportster/Buell Year: 1969 Other Motorcycle Model: Softail Slim Other Motorcycle Year: 2016
If the backfire occurs when you are less than 1/4 throttle open, you need to adjust with the idle screw. If it occurs between 1/4 and about 3/4 throttle , you adjust the clip on the piston
‘s needle valve. If it occurs from 3/4 to wot, you replace the main jet , located inside of the float float bowl behind the drain plug.Ihave used the 38 mm VM on all of my my old bikes since the 1970’s and it is my favorite carb. They are incredibly smooth and easy to adjust. I had problems with one Mikuni I bought on EBay years ago and found that a po fooled around with the jets. The best out of the box Mikuni kit you can buy is from the Sudco Company. I’ve had the occasion to buy from them a number of times and , most of the time, the carbs were set dead-on right out of the box, aside from idle speed.
1 Week Ago
Posts: 723 Sportster/Buell Model: sportster stroker xlch Sportster/Buell Year: 1970 Sportster/Buell Model #2: sportster xlh Sportster/Buell Year #2: 1973 Other Motorcycle Model: 99 inch sportster Other Motorcycle Year: 2003
I put a VM38 on the '74 XLCH I bought and now it backfires through carb when I get on the throttle, if I put the enrichner on a little it's not as bad, turning the air adjustment screw does not help. It starts and idles fine. Does not backfire with the S&S that was on it when it bought it.
Skipping the rants and getting back to topic here.
As JB in NC stated eliminating the pop can be as simple as moving the needle clip down to richen the mix.That procedure will take less than 15 minutes and no expense. Last point make sure there is no slack in the throttle cable.
1 Week Ago
never heard of a throttle cable causing backfire
1 Week Ago
Posts: 7,195 Sportster/Buell Model: XL77.2R Sportster/Buell Year: 2006
That cable control the carburetor, first to be checked.
1 Week Ago
Posts: 11,367 Sportster/Buell Model: XLCH Sportster/Buell Year: 1975
Define “…when I get on the throttle…”. If you are quickly/sharply snapping the throttle open that might be the whole problem - there is no accelerator pump to richen the lean spot created from opening the throttle like that. The super e has a pump on it so you don’t really get the lean backfire from that carb. Or maybe an intake o-ring leaking by unmetered air is another possibility to consider. “If I put the enrichener on it’s not as bad” - I say check for intake air leak next.
1 Week Ago
The Mikuni dos have a great snappy throttle response without an accelerator pump. It is not normal for a Mikuni to backfire or miss if it's i dialed in properly. If there is an issue with quickly turning the throttle, it can be adjusted out.
