Keep & Kill
VP fuel
Last Post: hbkeith
Backfire
1 Week Ago
Posts: 723 Sportster/Buell Model: sportster stroker xlch Sportster/Buell Year: 1970 Sportster/Buell Model #2: sportster xlh Sportster/Buell Year #2: 1973 Other Motorcycle Model: 99 inch sportster Other Motorcycle Year: 2003
Originally Posted by Ferrous Head
Anyone who believes that has never seriously looked at air flow requirements for an engine.
Port velocity is directly tied to the capacity of the engine and size of the venturi of the carburetor. A 38mm carb is simply not suited to a 123cc or a 1,376 cc engine. It will not work worth a fart on either of them.
A VM38 tells you the venturi size is 38mm. A VM28 may well work on a 125 but a 38 is not going to.
Technically, no. The VM series having 5 circuits as opposed to the S&S's 3 means you can "fine tune" the VM much closer too perfect than you can an S&S.
But will you ?
Because most people simply don't. They just want a carb that will run "acceptably". They don't like "sags" bogs", coughing" or "pops".
IF, you know what your doing and if you spend the time and money to dial in a Mikuni it will perform marginally better than an S&S. Maybe.
I would love to see someone make a VM38 work on a 125cc engine. Maybe at 48,000 rpm ?
Amazon sells a JFG Racing pwk (generic)38mm for 150cc cost is $36.
1 Week Ago
Posts: 162 Sportster/Buell Model: sportster Sportster/Buell Year: 1968
Did not mean to ignite a firestorm just wanted some suggestions on getting rid of the backfire. That being said, I will try some of the suggestions one at a time to see what works, starting with the air flow adjustment needle, right now it is out 7/8th of a turn. Next will be the adjusting the clip on the needle one notch at a time.
As I said I am 80yrs old so my reflexes are quite slow I roll on the throttle kind of gently, I really have not noticed at what rpms the backfire occurs, I will take note on my next ride.
1 Week Ago
Posts: 42 Sportster/Buell Model: XL 1200 Sportster/Buell Year: 2000 Sportster/Buell Model #2: XL 1200 Sportster/Buell Year #2: 1993 Other Motorcycle Model: H-D FLH Other Motorcycle Year: 1980
A man much wiser than I once told me that if you are tuning something you are not familiar with, make big changes. That should show you if you are going in the right direction. (At the time I was teaching myself to tune carbureted nitro.) That's why I suggested that you move the needle clip two notches. You may trade one tuning issue for another, like going from too lean to too rich, but at least that will tell you if you are going in the right direction, or even adjusting the right thing. The fine-tuning comes later.
By the way, most advice given above is based on your use of the term "backfiring." I (and others, aparrently) take that to mean popping out of the carb, indicating a lean condition. If you mean by "backfiring" the motor popping in the pipes, that would indicate a rich condition, maybe accompanied by a vacuum leak. Better clarity of terms will always help when it comes to these discussions.
Best of luck with it. A 38mm round slide works well on that size motor.
Jim
1 Week Ago
Posts: 3,006 Sportster/Buell Model: xlch Sportster/Buell Year: 1964 Sportster/Buell Model #2: XLCH IR EFI Sportster/Buell Year #2: 1971 Other Motorcycle Model: BMW K1200RS Other Motorcycle Year: 2001
Just a statement.
Choke on Mikuni VM is on when pressed down (enrichener circuit open)
S&S enrichener is on when lifted up (with stock S&S cover and lever)
May not be the case here, but I have seen operators thinking the opposite.
6 Days Ago
Posts: 8,562 Sportster/Buell Model: XLB, XLCH, Sporton Sportster/Buell Year: 1962 Sportster/Buell Model #2: XLCH Sportster/Buell Year #2: 1966 Other Motorcycle Model: XLCH (Another one) Other Motorcycle Year: 1966
Well, that would be perfect for my lawnmower. Get some SERIOUS HP out of that sucker.
6 Days Ago
Posts: 583 Sportster/Buell Model: XLH Sportster/Buell Year: 1969 Other Motorcycle Model: Softail Slim Other Motorcycle Year: 2016
Don't worry about the rpm range much in figuring this out. With this carb just try to take note of where about your throttle position is: 1/4 open, 1/4--3/4, or wide open. Usually the starting point for idle mixture tuning is about 1.5 turns out. Turning the idle mixture screw inward ( clockwise) richens the mixture (the opposite of many other brand carbs).
6 Days Ago
Posts: 972 Sportster/Buell Model: 883 Evo Sportster/Buell Year: 1989
Have a nice day
6 Days Ago
Have a nice day
6 Days Ago
Have a nice day
6 Days Ago
Sorry mate, it's not really a "firestorm" (Isn't that a Honda ?) it's just the way we hold conversations on the forum.
You'll find most who answer you are just trying to help. Generally, with their own experiences as a guide.
If you truly want to start a firestorm, just mention the brand of oil you use.
