Keep & Kill
Tank Art
Last Post: joe s
2 Weeks Ago
Posts: 70 Sportster/Buell Model: XLCH Sportster/Buell Year: 1972
Oiler plug without hole
Was putting my trans together and happened to notice that the oiler plug is sans a hole. Should I get a new one or attempt to put a hole through it myself?
2 Weeks Ago
Posts: 1,901 Sportster/Buell Model: xlh Sportster/Buell Year: 1974
It looks like there is something stuck in the end of the hole. If there really isn't a hole, You've nothing to lose by giving drilling a try. What's the worst that could happen? Broken drill?
The hole is 3/32"
2 Weeks Ago
Posts: 734 Sportster/Buell Model: sportster stroker xlch Sportster/Buell Year: 1970 Sportster/Buell Model #2: sportster xlh Sportster/Buell Year #2: 1973 Other Motorcycle Model: 99 inch sportster Other Motorcycle Year: 2003
Looks like a factory plug so just dig a bit from both sides and get the crap out.
Remember to install the plug hole facing up! The splashing primary oil goes in the hole and lubricates the C/S bearing.
2 Weeks Ago
Thanks guys!
2 Weeks Ago
Posts: 15,898 Sportster/Buell Model: XLCH stroker Sportster/Buell Year: 1960 Sportster/Buell Model #2: 883 C Sportster/Buell Year #2: '03
my oil hole was plugged with dirt.the trans.started making a rumbling noise.took it apart and found the rollers in the open end bearing were cocked on an angle with no visible oil.
2 Weeks Ago
That was a good catch.
Lesson to be learned here is when you hear something sounding off kilter check it out.
2 Weeks Ago
Posts: 3,020 Sportster/Buell Model: xlch Sportster/Buell Year: 1964 Sportster/Buell Model #2: XLCH IR EFI Sportster/Buell Year #2: 1971 Other Motorcycle Model: BMW K1200RS Other Motorcycle Year: 2001
Check the top trough in the case as well.
2 Weeks Ago
There was definitely metal blocking the hole. I ended up using a small hacksaw and taking off the very end which then revealed the hole. I then took a 3/32 drill bit and opened it all the way up. Finished off the rough edges with sandpaper and cleaned everything up with brake clean. Should be good to go.
Thanks for all the replies!
And [mention]Iron Mike [/mention], what do you mean by the top trough?
2 Weeks Ago
you've cleared the inside hole.how does the outside hole look?are you able to blow compressed air through it?
2 Weeks Ago
Top trough inside the case trans cavity (on the roof of trans cavity) feeds right side bearing. Probably has the same amount of crud in there.
