Last Post: FiftySixer
0 900cc Cylinders
Last Post: Staffords
0 Speedometer Replacement - 2011 xl1200cp - how to remove
0 Hagerty Insurance
Last Post: Akdawg
0 1275 Kit and Krome Werks Headers?
Last Post: XL1275
Last Post: Slytat
0 CV-40 for 88’ 883 Still leaks overflow/rebuilt
Last Post: Mission1
0 wavers
Last Post: ZCarFan
0 tachometer on 2012 Custom
Last Post: The Doctor71
0 Kinda of a Dumb Question on Top End Build coming up
Last Post: XL1275
0 Early Sportster Shock Absorber Disassembly
Last Post: Heff
0 New from Michigan
Last Post: 1skullster1
0 Fuel Sputter & Much More
0 Another Ohio Meet & Eat?
0 Rear wheel alignment
0 low rpm problem
0 Help Identifying Pistons
Desertfox (70), gd714 (60), insalltm (57), seagullplayer (55), ac_tx, jon686 (49), NineSixteen (45), dstroy12 (38)
Old 23rd June 2020
Seanu30 Seanu30 is offline
Sportster/Buell Model: 883 Iron
Sportster/Buell Year: 2020
Seanu30 is an unknown quantity at this point
Default XL 1200CX Wheels on 2020 883 iron
Looking at swapping out the stock wheels on my 2020 883 iron with a set of the wheels from a 2016 XL 1200CX (Front 19x3 and Rear 18x4.25).
Has anyone done something similar to this and if so, was there any modifications that needed to be done or specific tire(s) that should be used?
Old 23rd June 2020
Bluto Bluto is offline
Other Motorcycle Year: 1973
I installed the rear on my 2008 XL1200R and it was a direct swap...however the front will not work with the narrow glide forks on my bike or yours. Rear tire is a 150/70-18, I'm running a Pirelli Scorpion Trail II and like it a lot, on my second one...
Old 23rd June 2020
Thanks BLuto.
Do you have chance have the PN to that wheel?
Old 23rd June 2020
yep rear wheel pn is 40900399, about $330 from the online HD parts vendors Wheel is bare so you need an installation kit 41451-08C or bearings, spacer, and stem ordered separately...
New wheel and tire (Dunlop American Elite 180/55-18). Had enough room without making modifications with the exception of removing the belt guard.
https://photos.app.goo.gl/NV7hbRJAFWthh9Hx9
https://photos.app.goo.gl/bTWjSaGn63vab4oc8
Sportster/Buell Year: '59
Other Motorcycle Model: 2006 XL1299R
PetesPonies has a brilliant futurePetesPonies has a brilliant futurePetesPonies has a brilliant futurePetesPonies has a brilliant futurePetesPonies has a brilliant futurePetesPonies has a brilliant futurePetesPonies has a brilliant futurePetesPonies has a brilliant futurePetesPonies has a brilliant futurePetesPonies has a brilliant futurePetesPonies has a brilliant future
I added midglide trees to my '06 Roadster to fit 16 x 3 front wheel. Should work for your front wheel choice as well.
Pete's Ponies Mustang RUSToration & Performance . . retired Auto Instructor
Old 6 Days Ago
Pete,
Where did you get your mid glide conversion from?
Old 6 Days Ago
A few years back someone here installed a XL1200CX front wheel on a regular Sportster using mid glide triple trees and IIRC they needed to make custom axle spacers as the upside down CX forks are not exactly midglide width. I don't recall if brake caliper spacing was an issue. So anyway it can be done but it isn't a direct swap like the rear CX wheel on 08+ Sportsters...
Old 6 Days Ago
Pete,
I didn't buy any conversion. What I was doing was totally custom. I have a Roadster, so dual front discs. I also wanted a 16 x 3 wire wheel. There was nothing to draw from, had to find what would work and make the rest. I bought trees used, from a Forty Eight. I couldn't use that axle or wheel, didn't work for what I was doing. I used my lower legs, since they were dual disc. I then had to fab an axle to work with the axle size from my '06 Roadster. I bought a used BT axle, plenty long , but the right diameter. I cut it shorter and on a lathe, I turned down what needed to be turned to remake the left end, and threaded it. Then of course I made spacers. I was using Tokico calipers, so I already had spacers for them, but had to add some to work with the mid glide. I ended up using a rotor spacer on one side. It was a job, figuring out everything. I laced my own black rim to chrome spokes as well.
Old 6 Days Ago
See http://xlforum.net/forums/showthread...1989881&page=3
and https://www.hdforums.com/forum/sport...wheel-p-n.html
for more info on getting the front CX wheel to fit with midglide triple trees...
