0 Morning default to odometer
Last Post: Eric Von Zipper
0 Tuners
0 Sportsters in movies and TV
0 Your never too old
Last Post: leon bee
0 '66 XLCH Repro Bars? (VM38 Conversion Continued)
Last Post: ProLibertate
Last Post: sportymike02
Last Post: Zip1
Last Post: ronccc
0 Ironhead heavy duty cable amps ?
Last Post: Uberstorm
0 Xl for sale
Last Post: jeosbolt
Last Post: chardhin
0 72 XLCH clutch ball and ramp system
Last Post: Zoo
0 Pawl Carrier Support Bushing ???
0 E85
0 Sportster drag bike
Last Post: Zip1
0 Cosmo's ECM Relocation Mod
0 Throttle side turn signal failure
Last Post: OntarioIron
Last Post: 1200CustomHD
oldsporty1 (70), paris15 (62), thesmithiz (62), pajimmyjoe (61), chuckam (57), steve w (51), le_strike (44), Rubicon (38), r3db3ard3d (32), rortiz76 (32)
Old 14th August 2020
canoli's Avatar
canoli canoli is offline
Ah nice, wires outside. I just changed my bars last wknd and ran the wiring inside. Oh well it shouldn't be too hard making the electrical connection. I need to find the thread pitch of the master cylinder banjo bolt I guess.
EDIT: banjo fitting size/TPI on the m/c is 7/16-24.
Thanks for sharing what you did - a banjo switch sounds like a great fix.
Old 23rd August 2020
canoli's Avatar
Default Finally fixed
'92 XLH 1200
My brake light is now working correctly. Thank you to PetesPonies for the suggestion (and the pic) of a banjo switch, which I installed without much trouble this morning. It works perfectly. Installing a banjo pressure switch is such an easy, smart fix.
I never figured out what the problem was but I understand (after lots of YT) it's a common occurrence on Harley brake levers/switches from that era. Later they went to a better system where the tab that activates the plunger on the brake switch is part of the brake lever. But these older ones with the master cylinder pushrod do suck indeed and I'm glad to be rid of it!
Thanks again!
