Keep & Kill
Chrome
Last Post: Andy Hog
7th January 2022
Posts: 7,238 Sportster/Buell Model: XL77.2R Sportster/Buell Year: 2006
Adjust your carburetor with ethanol free gasoline if you can find some.
Using premium gas is not recommended to tune the carb if you'll be using regular in your tank.
7th January 2022
Posts: 3,371 Sportster/Buell Model: XL1200C Sportster/Buell Year: 2017 Other Motorcycle Model: BMW R9T Other Motorcycle Year: 2015
Originally Posted by dyno
While decelerating only
Have you adjusted the idle mixture screw for best idle?
Try screwing the idle mixture screw in 1/2 turn and see if that helps the popping.
7th January 2022
Posts: 1,039 Sportster/Buell Model: XL883-1200 Branch Build Sportster/Buell Year: 2000
I get a little popping on deceleration but not really any major gain or loss of power
when hard on throttle and letting off quickly will cause a quick lean situation since cutting fuel and air ratio goes up.
That is normal.
Happened to me. Plus I have a 2000 and mechanical reserve on tank. I can usually tell getting low on gas when starts to pop and stutter then quickly put tank on reserve.
7th January 2022
Posts: 803 Sportster/Buell Model: sportster stroker xlch Sportster/Buell Year: 1970 Sportster/Buell Model #2: sportster xlh Sportster/Buell Year #2: 1973 Other Motorcycle Model: 99 inch sportster Other Motorcycle Year: 2003
Just to be clear the roll off test starts at full throttle and ends at 7/8 throttle and hold.
Refer to the Mikuni HSR48 Manual.
8th January 2022
Posts: 3,588 Sportster/Buell Model: XL1200X Turbo 48 Sportster/Buell Year: 2011 Sportster/Buell Model #2: XL1200 Roadster Sportster/Buell Year #2: 2008
One change at a time.
8th January 2022
Posts: 7,530 Sportster/Buell Model: 883 Xl Sportster/Buell Year: 1992
First time post here
have an 06 883 with the 1275 120+ kit
installed hammer's 120+ hp kit with the HSR48 and am looking to see what main jet has worked in the past for others. it came with a 190 and seemed to be running lean (not terribly lean) but none the less just looking to see what others have ran in regards to this kit/carb combo.
Thanks
Andrew
I think I ended up in the 185-192.5 range. As others have stated, the mik tuning manual is pretty darn good. I’ve never been above a 195 main, 48 mik on pump gas. That’s running 91 corn gas, same ish kit as you have.
