0 What's up guys
0 No click
Last Post: HarleyAsh
0 1974 XLH Rebuild
Last Post: Gearhead88
Last Post: maltesefalcon
Last Post: jeffro57
0 Conversion Kit Choices
Last Post: bagster guy
Last Post: gearbanger
0 Change engine sprocket
Last Post: FrameMount1200
0 DK Custom Products License Plate Relocations
Last Post: Melnic
0 Pinehurst NC
0 You can't tour on that!!!
0 FNG from Tuckasee
Last Post: PoodlePunche
0 Increase Low & Mid Range Torque w/ STOCK Exhaust! Get a Better Sound Too!
0 Primary Cover
0 cam options
0 Allegheny 2023
3 Wtb, Wts, Wtt, Wtg (Evos)
Last Post: wolfryder
0 Sumped oil.
actuator, clutch, ramp
Old 3rd April 2022
wedge's Avatar
wedge wedge is offline
The balls should make it to the ends of both ramps regardless weather they slide or roll.
Old 3rd April 2022
staniel staniel is offline
Sportster/Buell Year: 1972
Sportster/Buell Model #2: XL1200CX
Sportster/Buell Year #2: 2019
Other Motorcycle Model: FXFBS
Other Motorcycle Year: 2021
staniel is a name known to allstaniel is a name known to allstaniel is a name known to allstaniel is a name known to allstaniel is a name known to allstaniel is a name known to allstaniel is a name known to allstaniel is a name known to allstaniel is a name known to allstaniel is a name known to allstaniel is a name known to all
So I checked the clutch, there are no spacers for the springs. Not sure how you would even measure the 11/32" clearance... Def need the clutch puller if I even want to loosen the adjusting nuts.
When I took the cover off, I removed the grease that I had put on the clutch ramp, reassembled the clutch ramp, and did the clutch adjustment process, but again, the clutch is like a rock.
I can adjust the free play all I want, but as soon as the free play is taken up, it's like the clutch pin is pushing on a rock wall. It's so stiff that I'm bending my clutch perch.
Running out of ideas here...
Old 3rd April 2022
What exactly am I supposed to be measuring here? It doesn't look like the clutch shown in the manual
Old 3rd April 2022
Sportster/Buell Year: 1974
From the releasing disk surface that the six nuts are on, measure straight in from the outer edge of the releasing disk to the outer drive plate. (thats the thing retained by that big wire ring.)
Loosen (or tighten) the nuts evenly till it measures 11/32. Judging from the amount of thread extending from the nuts it looks like they may be tightened all the way down. If so the clutch won't release.
Refer again to post 18.
http://xlforum.net/forums/showthread...=922144&page=2
Old 3rd April 2022
So I measured and set the clearance there to 11/32 then did the clutch adjustment process and still no dice.
I pull the clutch lever and it locks up as soon as you pull through the 1/8'' free play.
Old 4th April 2022
From that pic it looks like the pressure plate nuts are driven on too far.
Are there sleeves on the studs behind the pressure plate?
Old 4th April 2022
I don't know what year they updated the wet clutches. The preferred setup,I believe, is the later steels and sleeves. Measure the sleeves to make sure they have not been crushed. Early style adjustable can be changed to sleeves by adding sleeves and clearancing/replacing steels.
Always use new nylocks on the pressure plate.
