0 What's up guys
0 No click
Last Post: HarleyAsh
0 1974 XLH Rebuild
Last Post: Gearhead88
Last Post: maltesefalcon
Last Post: jeffro57
0 Conversion Kit Choices
Last Post: bagster guy
Last Post: gearbanger
0 Change engine sprocket
Last Post: FrameMount1200
0 DK Custom Products License Plate Relocations
Last Post: Melnic
0 Pinehurst NC
0 You can't tour on that!!!
0 FNG from Tuckasee
Last Post: PoodlePunche
0 Increase Low & Mid Range Torque w/ STOCK Exhaust! Get a Better Sound Too!
0 Primary Cover
0 cam options
0 Allegheny 2023
3 Wtb, Wts, Wtt, Wtg (Evos)
Last Post: wolfryder
0 Sumped oil.
  #71
Old 14th January 2023
rejeanprimeau's Avatar
Get the correct o-rings, see what happen to the challenger space shuttle when the used a smaller id gasket to be able the fit the bell of the joint. They just snap to get back to their nominal id.
sifty sifty is offline
Sportster/Buell Model: ironhead XL
Other Motorcycle Model: Triumphs BSA's Hondas
Other Motorcycle Year: '32>
sifty has a brilliant futuresifty has a brilliant futuresifty has a brilliant futuresifty has a brilliant futuresifty has a brilliant futuresifty has a brilliant futuresifty has a brilliant futuresifty has a brilliant futuresifty has a brilliant futuresifty has a brilliant futuresifty has a brilliant future
I've got them, just not sure which ones they are.
Would be nice if the James full gasket kits came with a list of what o-ring went where, or even if they were bagged by Harley part #...
Originally Posted by Iron Mike View Post
The gasket kit includes pushrod tube o-rings for the later models.
Excellent, that makes sense. Found this which really helps...
So looking at what I have I think the o-ring dimensions are:
[OD, ID, thickness]
11101 - 15/16, 3/4, 3/32
11132 - 7/8, 11/16, 3/32
11190 - 15/15, 11/16, 1/8
So that pack of 14 o-rings are all 11101. Cheers...
Old 15th January 2023
Sportster/Buell Year: 1974
Hi Sifty, I'm getting an education from reading your thread. Before this I never knew that later models used O rings for pushrod tube seals instead of corks. The James gasket set has gaskets and seals to cover a range of years.
So I wondered what year would use all of the 14, 11101, 15/16 x 3/4 x 3/32 O rings that are in the set.
Looks like a 1979 kick start would use 13.
(8) used on the pushrod tubes. (4 at the tappet and 4 at the rocker cover)
(4)used on the rocker arm shafts.
(1) used for the kickstart shaft. There is also one shown for the kick start hole plug. But Can't use both at once.
( Some other years use a different O ring size at the rocker cover)
Interesting. I don't have a 79 parts manual so didn't know where else they were used. I've just got lots of spare rocker arm ones.
Cheers...
Old 28th January 2023
Stuck in the 'waiting for parts' stage, so not much progress, few bits and pieces arriving but I've been busy with other things as well. (I do a bit of brewing so have put a couple of beers down)...
Decided to clean the engine up a bit and give it a 'spray bomb' rebuild once the dirt and oil was off, so masked things up...
And it came out ok with some high-temp black...
I did consider taking heads off for a proper clean, but the compression tests came out really well so decided to leave things alone. Should be able to start putting things back together soon...
Sportster/Buell Year #2: '03
paint looks great.how do the lifters look?
Ferrous Head's Avatar
Sportster/Buell Year #2: 1966
Image: https://aus01.safelinks.protection.o...%3D&reserved=0
Wondering if this might be a common thing among IH owners. I know "Hennessee" from "The Other Forum" is a master brewer too.
Maybe they drive you to drink...
Yeah it's an interesting hobby. Grow my own hops too.
Only pulled one lifter so far but looked good.
Old 29th January 2023
He grows his own.
Hops Too !
Do I drink because I have IH's or do I have IH's because I drink. That is the question.
