0 What am I doing wrong?!
Last Post: NP72Iron
0 Vintage Sportster seat?
Last Post: rocketnorton
0 Handlebar Question - collar
0 Hey from Louisiana
Last Post: wolfryder
Last Post: ZTatZAU
0 cam options
0 Clutch Spring plate poll
Last Post: Andy56
0 Allegheny 2023
0 IH Horns and Fixins
Last Post: Turbo Sporty 48
Last Post: wachuko
0 CV on an Ironhead
0 ***DK Custom - *NEW* Outlaw HiFlow 828 A/C Complete System!***
0 02 sporty 1200c banjo size
Last Post: Billy1200
0 Hello from Gloucester UK
0 Sportster drags
Last Post: conv90
0 You can't tour on that!!!
0 Torque is never enough
tom32, shaky jake (70), pepper (67), Farseeker (66), Nibelungen (56), Mike-883R (53), cbrunson (48), jcs75sporty (48), Locust (46), bob1610 (41), bigsporty1 (40), ImAHighSamurai (37), OleEven (36), ofaloto.tupi (36), mitch32592 (31)
compression, ironhead, sportster
Old 26th June 2012
fryday4748 fryday4748 is offline
Sportster/Buell Model: Ironhead sporster
Sportster/Buell Year: 1982
Other Motorcycle Model: Triumph sprint 900
Other Motorcycle Year: 1996
fryday4748 is an unknown quantity at this point
Default cant find this info
Whats the compression supposed to be on an 82 sporty?
Old 26th June 2012
runingmouse runingmouse is offline
Sportster/Buell Model: xlx
Sportster/Buell Year: 1985
Sportster/Buell Year #2: 1979
Other Motorcycle Model: Sprint ss
Other Motorcycle Year: 1967
runingmouse has a spectacular aura aboutruningmouse has a spectacular aura aboutruningmouse has a spectacular aura aboutruningmouse has a spectacular aura aboutruningmouse has a spectacular aura aboutruningmouse has a spectacular aura aboutruningmouse has a spectacular aura aboutruningmouse has a spectacular aura aboutruningmouse has a spectacular aura aboutruningmouse has a spectacular aura about
well here is what the FSM manual says.
If the final readings are 120 psi. or more, and final readings do not indicat more than a 10 psi. variance between cylinders. Thats considerd nomal.
this may also help u from stickys - http://xlforum.net/forums/s...ad.php?t=48311
Old 26th June 2012
gungatim gungatim is offline
Sportster/Buell Year: 79
Other Motorcycle Model: Yamaha TX500
Other Motorcycle Year: 74
gungatim has a spectacular aura aboutgungatim has a spectacular aura aboutgungatim has a spectacular aura aboutgungatim has a spectacular aura aboutgungatim has a spectacular aura aboutgungatim has a spectacular aura aboutgungatim has a spectacular aura aboutgungatim has a spectacular aura about
Compression:
79-81 is 9.0:1
1982 is 8.0:1
83-85 is 8.8:1
Actual PSI in the cylinder will vary but 120-140 is pretty typical.
Old 26th June 2012
i got 75-80 on each cylinder. but i think i did it wrong. i didnt have the choke ope nor did i have the throttle and slide open all the way. so im gonna re-check it this evening when i get home. im hoping it comes up. she runs good but i am a tinkerer and cant keep my hands off of it lol.
Old 26th June 2012
For a valid static compression test ...
  1. Engine must be at full operating temperature
  2. Throttle plate must be fully open [throttle grip twisted fully]
  3. Choke plate must be fully open [choke knob not pulled out]
If carb has an enrichener rather than a choke then it is irrevelent.
Old 26th June 2012
squirt squirt is offline
squirt is an unknown quantity at this point
I find that these numbers are a good starting point for just about any gas engine... Car, truck, motorcycle.
In my opinion, the critical factor here is consistency from cyl to cyl. An older engine that's a bit tired may have slightly lower numbers, but it's not a big deal unless one is reading 90 and the other 120.
