0 Handlebar Question - collar
Last Post: Mendonjo
0 Hello from Gloucester UK
Last Post: maltesefalcon
0 My new ride
Last Post: XLVIII
0 Vintage Sportster seat?
Last Post: ZTatZAU
0 Vital V-Twin Cycles
Last Post: DrMotorcycle
0 Torque is never enough
Last Post: conv90
Last Post: BWP 5p
0 CV on an Ironhead
0 12v power for charging.
0 Video - The Comfort Triangle - Set Up Your Harley for You
Last Post: cookiemech
0 stress killer
0 Conversion Kit Choices
Last Post: ReddTigger
0 Change engine sprocket
Last Post: bagster guy
0 Primary
Last Post: koolbreeze
0 1974 XLH Rebuild
Last Post: Gearhead88
0 Sportster drags
0 You can't tour on that!!!
mike, Rick572 (76), Tailchaser (75), Back Road (59), sanman12002003 (58), LilMsRida (58), wargod1 (54), tplyons (36), DOM! (35)
gasket, pushrod, rocker cover
Old 15th April 2013
Freelander03 Freelander03 is offline
Sportster/Buell Model: XL 1000 75th Anniversary
Freelander03 is an unknown quantity at this point
Default Rocker Cover Gasket Replaced & Bike Sounds F-d Up!
I changed the rocker cover gasket out and started up my '78. It ran rough--choppy-like--for about 5 minutes. Once it got warm, and the idle crept it's way down towards 1,100, it stalled. It did this 3 times. I revved-up the engine a couple of times, and each time, when the rpm's came down from 2,500, the idle would hold for a second or two at 2,000, then come down slow and stall out at 1,000. I reset the S&S carb, but once I did that I couldn't start up the bike again.
I suspect I have to have the pushrods adjusted before anything else... I do not have a lift, so I'm waiting for my local shop to call me, once they have an open slot--they're busy with Spring-time, incoming Harley's... I just have to wait my turn
Old 15th April 2013
chevelle chevelle is offline
Sportster/Buell Year: 19**
Sportster/Buell Year #2: 1965
Yes you need to set pushrods.
Very easy, no lift needed.
Check stickies for procedure.
Old 15th April 2013
72 Ironhead XLH's Avatar
Sportster/Buell Year: 72
this was the front cyl rocker box? then you had to loosen the rods first ,then remove the cover. you cant just unbolt it and expect the rods to hold the setting.
Old 15th April 2013
@ chevelle: where are these stickies you speak of???
Old 15th April 2013
@ 72 Ironhead XLH: Yea, front cover; I realized the rods would be an issue post facto.
Old 15th April 2013
nikki's Avatar
nikki nikki is offline
Sportster/Buell Year: 1982
nikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of light
in the top section of the front page above the topic in the forum . Nikki
Old 15th April 2013
there the ones in RED
Old 15th April 2013
Vermonter Vermonter is offline
Sportster/Buell Year: 1973
Other Motorcycle Model: 80XS650/71CL175/7?gs550
Vermonter is a glorious beacon of lightVermonter is a glorious beacon of lightVermonter is a glorious beacon of lightVermonter is a glorious beacon of lightVermonter is a glorious beacon of lightVermonter is a glorious beacon of lightVermonter is a glorious beacon of lightVermonter is a glorious beacon of lightVermonter is a glorious beacon of lightVermonter is a glorious beacon of lightVermonter is a glorious beacon of light
There is a great video on YouTube about the pushrod adjustment. Read the sticky, watch the video, do it yourself. It will take you all of ten min. Your dealer will charge you one hour min... and probably do it wrong.
Old 15th April 2013
scottfisher scottfisher is offline
Sportster/Buell Model: FLCH
Sportster/Buell Year: 61
Sportster/Buell Year #2: 60
scottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to behold
pushrod sticky:
http://xlforum.net/forums/s...ad.php?t=44143
s
Old 15th April 2013
Does the wooden 4"x8" make-shift lift really work???
