0 Conversion Kit Choices
Last Post: ReddTigger
Last Post: Sportster25
0 Hello from Gloucester UK
0 Torque is never enough
0 Change engine sprocket
Last Post: bagster guy
Last Post: DrMotorcycle
0 CV on an Ironhead
Last Post: Captain Johnny
0 Primary
Last Post: koolbreeze
0 1974 XLH Rebuild
Last Post: Gearhead88
0 Sportster drags
0 Vital V-Twin Cycles
Last Post: vitalvtwin
0 You can't tour on that!!!
0 Vintage Sportster seat?
Last Post: PoodlePunche
0 78 XLH project /new home
Last Post: Ted Town
0 Carb question
Last Post: rwharris
0 clutch cable
Last Post: 01rk
Wild One, Bugs (70), Blazer (67), OnDVirg (67), Buggyboy (64), TheChimp (49)
oil leaks, rocker cover
Old 11th May 2013
xr6004 xr6004 is offline
Sportster/Buell Model: 1999 XLH1200 Sportster
xr6004 is an unknown quantity at this point
Default Leaky rocker cover bolt
"99 Sporster Custom
I have one rocker cover bolt that weeps a little oil. I have installed a new bolt and gasket, but it still leaks. Any ideas out there.
Old 11th May 2013
1250IRON 1250IRON is offline
Sportster/Buell Model: Iron
1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light
gasket sealer then screw bolt in.
Old 11th May 2013
I tried that with the old bolt with no luck. Going to try it with the new bolt. Was just wondering if anybody else has seen this problem.
Old 11th May 2013
Going to examine the the bolt hole really close this time. Cracked maybe?
Old 12th May 2013
think they original had rubber washer gaskets. maybe try putting another on?
