0 What's up guys
0 No click
Last Post: HarleyAsh
0 1974 XLH Rebuild
Last Post: Gearhead88
Last Post: maltesefalcon
Last Post: jeffro57
0 Conversion Kit Choices
Last Post: bagster guy
Last Post: gearbanger
0 Change engine sprocket
Last Post: FrameMount1200
0 DK Custom Products License Plate Relocations
Last Post: Melnic
0 Pinehurst NC
Last Post: XL Ed
0 You can't tour on that!!!
0 FNG from Tuckasee
Last Post: PoodlePunche
0 Increase Low & Mid Range Torque w/ STOCK Exhaust! Get a Better Sound Too!
0 Primary Cover
0 cam options
0 Allegheny 2023
3 Wtb, Wts, Wtt, Wtg (Evos)
Last Post: wolfryder
0 Sumped oil.
cylinder, rear, sportster 1200
Old 29th June 2015
Other Motorcycle Model: Yamaha XT250
Other Motorcycle Year: 2023
Originally Posted by Rico 05R View Post
Crank Position Sensor
High probability, as George already suggested.
If coil tests good, then 99.9999% probability.
Old 30th June 2015
gmross gmross is offline
Sportster/Buell Model: XL 883L
gmross is an unknown quantity at this point
I would suggest checking that you don't have a leaking intake manifold. This was exactly my symptoms, removed the Carb and manifold and was then very very anal about tightening up the manifold in a very uniform manner.
Problem fixed that easily. Of course that's after a bunch of top end engine work and I chased the coil naturally first, and then pulled the side cover to check the installation of the new Cam set and then leaking intake.
Old 30th June 2015
gary450sl gary450sl is offline
Sportster/Buell Model: 883 lowrider stage 1
gary450sl is an unknown quantity at this point
Thanks guys I will check these bits tonight if I get time after work its nice and sunny and my ride don't go so not food
Old 3rd August 2015
s_howard s_howard is offline
Sportster/Buell Model: 1200xlc
Sportster/Buell Year: 04
s_howard is an unknown quantity at this point
Im having the same issue the back cylinder plug is always black and it looks a little wet.. and I stutters when I accelerate hard. I installed new plugs and new crankshaft sensor? but it runs perfect only problem is when I get on it? any ideas? 2004 sportster 1200xlc .
thanks
Old 4th August 2015
Is it missing or not firing at idle?
Based on the age I would suggest purchasing a new set of intake manifold seals. Be very anal as you reinstall the manifold and torque up the four socket head bolts very uniformly.
Solved my problem.
