0 Fried Engine?
0 Saturday Sportster Season 2
Last Post: bagster guy
Last Post: Captain Johnny
0 Starting my project soon.
Last Post: ankered
0 Fiber Washer on Idler Gear
Last Post: DirtyHarry68
Last Post: Jtl2
0 It's been a great Ride!
Last Post: ed_in_az
Last Post: joe s
0 Bad Speedometer or Bad VSS?
Last Post: cookiemech
0 Need a rear fender
Last Post: SporterII
0 1999 S upgrades
Last Post: 84rzv500r
0 a man walks into a bar
0 My off-road build
0 Allegheny 2023
compression, xlch
Old 14th April 2021
sungod's Avatar
sungod sungod is offline
Sportster/Buell Year: 1970
Sportster/Buell Year #2: 1973
Default 73 ironhead
Originally Posted by Dukegonzo View Post
Few things - pushrod adjustment complete, and no intake leak that I found from spraying starter fluid all over the place lol.
I did very briefly mention above smoke from exhaust. Grey smoke when I crack the throttle open quickly. No smoke when idling or riding, just when I crack it open quickly.
Will take new compression test shortly.
*EDIT* - Also I verified that is in fact the late 73' model.
Light colored smoke usually indicates water in the system.Are you running fresh fuel?The good news is 73 late jugs can re bore to i believe .070.
Old 14th April 2021
Fivecats's Avatar
Fivecats Fivecats is offline
Sportster/Buell Year: '68
Sportster/Buell Model #2: FXR
Sportster/Buell Year #2: '89
Other Motorcycle Model: R50/5
Other Motorcycle Year: '73
Fivecats has a reputation beyond reputeFivecats has a reputation beyond reputeFivecats has a reputation beyond reputeFivecats has a reputation beyond reputeFivecats has a reputation beyond reputeFivecats has a reputation beyond reputeFivecats has a reputation beyond reputeFivecats has a reputation beyond reputeFivecats has a reputation beyond reputeFivecats has a reputation beyond reputeFivecats has a reputation beyond repute
If you can get a leak down test it will be more info, let you know what is good & what's not.
Old 15th April 2021
The puff of smoke is fuel from the Accel squirter, normal when you grab a hand full with no load on the motor.
Old 15th April 2021
Dukegonzo Dukegonzo is offline
Sportster/Buell Year: 1973
Dukegonzo is an unknown quantity at this point
Gotcha. Running a SU Eliminator carb as well if that clears anything up.
Old 15th April 2021
Yes, brand new premium, drained the tank and carb before putting new fuel in.
Assuming the pistons in there are Standard - could I theoretically get away with a .010 bore?
Old 15th April 2021
Gonna order a leak down test kit and get to it next week. Gotta leave town tomorrow a.m for a few days.
Old 15th April 2021
kitabel kitabel is offline
Sportster/Buell Year: 1989
If the #2 intake cam were out of time to the pinion (1 tooth = 25.7 degrees):
Advanced: CCP too high
Retarded: too low
If a pushrod were too tight, that cylinder would stop working.
Old 15th April 2021
BigMek BigMek is offline
Sportster/Buell Year: 1982
BigMek has a reputation beyond reputeBigMek has a reputation beyond reputeBigMek has a reputation beyond reputeBigMek has a reputation beyond reputeBigMek has a reputation beyond reputeBigMek has a reputation beyond reputeBigMek has a reputation beyond reputeBigMek has a reputation beyond reputeBigMek has a reputation beyond reputeBigMek has a reputation beyond reputeBigMek has a reputation beyond repute
Personally I would only go for a re-bore as a last resort. Unless the cylinder walls are scored or otherwise damaged, there are a lot of other things that could cause low compression. Cylinder thickness is precious - don't use it if you don't have to.
If you do need to get them bored, your machinist will tell you how much they need to cut to clean them up. Each "step" is .010" but they may need to go more than one step if the damage is deep.
Old 15th April 2021
Sportster/Buell Year #2: '03
??? have you owned an ironhead? classic symptom of a tight pushrod is low compression.this is easily noticed on a kick start motor causing hard starting.but it will start and run fairly decent.
Old 15th April 2021
I haven't read anywhere that the OP held the throttle wide open for compression test.
