video & pics
Keep & Kill
18th August 2022
Posts: 59 Sportster/Buell Model: Sportster 1000xlh Sportster/Buell Year: 1979 Other Motorcycle Model: 1975 cb750
1979 1000 kick compression at very bottom?
I'm just finishing up replacing the transmission on my 1979 1000xlh Kickstart only. I have very little to do. I was putting back on the kick pedal assembly only to realize I'm only receiving push back at the very bottom of the kick motion (6 o clock rather than 9 o clock) my friend said that it had to do with the spring rite in back of the kick shaft (that the pedal assembly bolts too). But, even with the spring off... I still only get that compression feel at the very bottom when kicking. Do I have to go all the way back to behind the clutch basket, where the kick sprocket is, turn the shaft 90 degrees then, reassemble everything again? Or, is it a much easier (I pray) task?
18th August 2022
If that is the case...
If that is the case, and I would have to go all the way back.. can I just drill a hole in the other side of the shaft (90 degrees from current hole that pedal assembly bolts in) and fix the pedal there so that, compression will again start at 9 0 clock? Or... is that shaft set and need to be at a certain place in reference to something that it may incounter on the inside of the case. If it's just a simple repositioning of the shafts hole to turn and fix the pedal assembly... no problem. But, if it ABSOLUTELY needs to be turned because of what it contacts inside the case then, I will go all the way back. To any answers given,.. please, please be certain.. I don't want to kick the pedal to start and unknowingly break a tooth of a gear or something horrible. I appreciate all the help..as always!
18th August 2022
Posts: 4,935 Sportster/Buell Model: XLCH Sportster/Buell Year: 1969 Sportster/Buell Model #2: 1966 XLCH Other Motorcycle Model: BMW Twin Other Motorcycle Year: 82
A Service Manual that can be had used on eBay can clear up many Questions, to be involved with these Motorcycles the Service Manual and the Parts Books are Invaluable Tools, I am aware this reply is not what you are looking for
Cycle World Oct 1962:
18th August 2022
18th August 2022
I have both harley's parts catalog *79-*85 and clymer service manual. Neither is help in this matter.. I need one of the pros who have first-hand been inside a 1979 and can tell me, if I reposition the kick pedal assembly (on the shaft) back 90 degrees, does the actual shaft (have to) be in a certain position inside the cranckase.. will it break something if I just change the position (or the side) that the hole is on the kick shaft. From what I can tell, it doesn't matter but, I have not seen what is between the two outsides of the case.. I don't know (for sure) what the shaft contacts inside the crancase and I need to have a definite answer.
18th August 2022
Posts: 3,083 Sportster/Buell Model: xlh 1000 69 79 xlch Sportster/Buell Year: 1977 Sportster/Buell Model #2: 80 FXE 82FLH 83FXR Other Motorcycle Model: 78FLH 79xlch 96xl 79xlh
where's the kicker arm at full return position?
18th August 2022
sounds like the kick shaft was installed incorrectly, you'll need to remove clutch hub to remedy this.
18th August 2022
Posts: 466 Sportster/Buell Model: XLH1000 Sportster/Buell Year: 1977 Sportster/Buell Model #2: 2004 XLH1200Custom Other Motorcycle Model: 2007 FXDB Other Motorcycle Year: 2004
No short cuts to FIXING RIGHT! Ya done messed up but it ain't all that bad. Pull the clutch shell off to get access to the Starter Crank Gear. The slot on the transmission side rides in the Starter Crank Gear Stop. What I do is hook a bungee chord to the kicker arm and hook it to the seat mount. Now index the Crank Starter gear and snug the nut down. Slip the bushing, spring, gear and shell on. Remove bungee and test the kicker.
18th August 2022
I can't cut a slot in the kicker shaft, reposition the kicker arm assembly back 90 degrees and tighten? If I do decide to do it that way,. Will it hurt anything?
