0 Video - The Comfort Triangle - Set Up Your Harley for You
Last Post: maltesefalcon
Last Post: cookiemech
0 Vintage Sportster seat?
0 CV on an Ironhead
0 Torque is never enough
Last Post: 84rzv500r
Last Post: bagster guy
0 Hello from Gloucester UK
0 stress killer
0 Conversion Kit Choices
Last Post: ReddTigger
0 Change engine sprocket
Last Post: DrMotorcycle
0 Primary
Last Post: koolbreeze
0 1974 XLH Rebuild
Last Post: Gearhead88
0 Sportster drags
0 Vital V-Twin Cycles
Last Post: vitalvtwin
0 You can't tour on that!!!
0 78 XLH project /new home
Wild One, Bugs (70), Blazer (67), OnDVirg (67), Buggyboy (64), TheChimp (49)
cams, cylinder temp, hammer
Old 7th January 2023
sungod's Avatar
sungod sungod is offline
Sportster/Buell Year: 1970
Sportster/Buell Year #2: 1973
hummmm????
like the sun rising and the sun setting???
toilet swirl right or left???
High tide /Low tide
XL Dane XL Dane is offline
Sportster/Buell Model: Sportster 48, 1275
XL Dane is a splendid one to beholdXL Dane is a splendid one to beholdXL Dane is a splendid one to beholdXL Dane is a splendid one to beholdXL Dane is a splendid one to beholdXL Dane is a splendid one to beholdXL Dane is a splendid one to beholdXL Dane is a splendid one to beholdXL Dane is a splendid one to beholdXL Dane is a splendid one to beholdXL Dane is a splendid one to behold
Originally Posted by sungod View Post
How do your plugs compare?
Good idea, I checked and they look exactly the same.
Originally Posted by MODO SIKLER View Post
Plugged exhaust for one cylinder? ...due to rats or some other nesting critter? Happens commonly in certain areas.
Thanks for the idea, but no obstruction in the exhausts.
Originally Posted by shanneba View Post
Check for exhaust leaks at the head and at the O2 sensors.
A leak that allows outside air to the O2 sensor would have the ECU believe the mixture was lean, causing it to richen the mixture. (I would suspect a possible leak in the rear exhaust)
Do you have a PowerVision tuner?
If you do you can log the O2 sensor voltages front and rear.
You can also log the Rear cylinder head temp to see how it compares to your thermographic pictures.
Yes I have PV tuner, so I will try to see if front and rear are same. Will also try to check for intake/exhaust leaks.
Originally Posted by rejeanprimeau View Post
Front exhaust, heat travel back, been knowed since VTwin are born.
But this is also while idling..
Is the bike upright or on the stand at idle? Just wondering if the angle has any
impact on cylinder temp.
It doesn’t seem to make a difference.
shanneba shanneba is offline
Setup your PV log to log these items:
RPM
ET
MAP
Set AFR ( on 2014 + you may see a Lambda value instead of AFR ratio)
VE Front
VE New Front (Ve with fuel trims)
Front CLI (Short term fuel trim)
Front AFF (Long term fuel trim)
VE Rear
VE New Rear (Ve with fuel trims)
Rear CLI (Short term fuel trim)
Rear AFF (Long term fuel trim)
Front O2 V
Rear O2 V
IDC.F
IDC.R
IAT
Advance F
Advance R
INJ PW F
INJ PW R
The VE New and fuel trims will let you see the ECU adjustments.
The CLI and AFF are at 100 when no change is being made or you are in open loop using just the set VE values.
2013 XL1200C
SportsterPedia.com
kitabel kitabel is offline
Sportster/Buell Year: 1989
The original cause of the front cylinder running hotter (that's why the baffle is there)?
The rear cylinder gets oil thrown off the flywheels, and the front cylinder doesn't.
Sportster/Buell Year #2: '03
front cylinder running hotter is a known H-D trait post#17
http://xlforum.net/forums/showthread...=420459&page=2 i have no doubt the additional oil the rear cylinder gets splashed with also has a cooling effect.
Old 11th January 2023
tussuck tussuck is offline
Sportster/Buell Model: 883L
tussuck has much to be proud oftussuck has much to be proud oftussuck has much to be proud oftussuck has much to be proud oftussuck has much to be proud oftussuck has much to be proud oftussuck has much to be proud oftussuck has much to be proud oftussuck has much to be proud oftussuck has much to be proud oftussuck has much to be proud of
I thought the 'tuners' set the rear jug to run a little richer which helps in cooling given its shrouded by the front one when the bike is underway. I would say this is normal and not to worry about it.
