video & pics
Keep & Kill
View Poll Results: How do you upshift?
By sound only
775 |
75.32% |
By speedo and/or tachometer
125 |
12.15% |
Other method
129 |
12.54% |
27th May 2006
Posts: 184 Sportster/Buell Model: 1200XL Sportster/Buell Year: 2005 Other Motorcycle Model: Ultra Limited Other Motorcycle Year: 2014
How do you upshift?
Newbie question - going on a year in the seat on my '05 1200 C (no tachometer) and was wondering how the more experienced handle this... upon entering the highway with little or no traffic, how do you upshift and about what speed do you shift from 4th to 5th?
Thanks for the assists!
27th May 2006
Luvs me an artsy chick...
Posts: 11,844 Sportster/Buell Model: 883>1200 XLH Sportster/Buell Year: 97
I'm usually doing at LEAST 55 before I'm into 5th....usually more like 60-65...more if its busy on the freeway as I pull on...
You can easily exceed your local and state highway speed restrictions in 4th gear....third, if you do it right....
~Chuck
Occam's Razor...
XLF Tuning Stickies
27th May 2006
Posts: 6,106 Sportster/Buell Model: Custom Sportster/Buell Year: 05 Other Motorcycle Model: Suzuki GN400 Other Motorcycle Year: 1980
when I am getting on a highway,
I start cranking it up as I am entering so I will be going highway speed and able to blend into the moving traffic.
If there is no traffic as I am getting to the lane, I will really crank it up (because I like the noise it makes). Ten up into 5th at somewhere around 55 or 60 and then pull on it again to about 75-80.
Then I usually come back to earth and cruise at about 65.
27th May 2006
Posts: 1,268 Sportster/Buell Model: XL883 Sportster/Buell Year: 2005
same here, can cruise in 5th at 55 but not lower, will shift at about 65 mostly
27th May 2006
Posts: 3,291 Sportster/Buell Model: XL1199 (1200 Conv.) Sportster/Buell Year: 2005 Sportster/Buell Model #2: XR1200X Sportster/Buell Year #2: 2011
I shift more by feel than by sound. You can feel when the bike is ready.... When getting on the freeway I shift at about 60 or so....
27th May 2006
US NAVY Vet, ADR2
Posts: 2,034 Sportster/Buell Model: XLH1200 Sportster/Buell Year: 1994 Other Motorcycle Model: FXD SuperGlide Other Motorcycle Year: 2005
My gal will pull 5th at 50, but I pull up to 60 before shifting when matching speed on highway ramps. Like to be able to twist & scoot if I need to. Just normal accel on reg roads, usually go into 5th at 55. Like The Preacher said, mostly by feel.
27th May 2006
Posts: 4,323 Sportster/Buell Model: 883 XLC Sportster/Buell Year: 2004 Other Motorcycle Model: FXDWG Other Motorcycle Year: 2012
Depends on traffic. If there's a lot I'll wind it up a little more to make sure I've got the juice to get out of a tight spot if needs be.
27th May 2006
Posts: 2,669 Sportster/Buell Model: XL1200R Sportster/Buell Year: 2006 Other Motorcycle Model: Victory High-Ball Other Motorcycle Year: 2013
Sound+Feel, I dont really like to just choose one, but i chose sound on the vote.
27th May 2006
Posts: 2,492 Other Motorcycle Model: A Hawg Other Motorcycle Year: 06
By feel..........
27th May 2006
Posts: 930 Sportster/Buell Model: 1988 883/1250
No tach or speedo so sound and feel  (or highway)
