Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE FORUM > Lubrication and Lubricants
Lubrication and Lubricants You guessed. Here is where everyone can argue over oil.
0 Conversion Kit Choices
Last Post: Sportster25
0 Hello from Gloucester UK
0 Torque is never enough
0 Change engine sprocket
Last Post: bagster guy
Last Post: DrMotorcycle
0 CV on an Ironhead
Last Post: Captain Johnny
0 Primary
Last Post: koolbreeze
0 1974 XLH Rebuild
Last Post: Gearhead88
0 Sportster drags
0 Vital V-Twin Cycles
Last Post: vitalvtwin
0 You can't tour on that!!!
0 Vintage Sportster seat?
Last Post: PoodlePunche
0 78 XLH project /new home
Last Post: Ted Town
0 Carb question
Last Post: rwharris
0 clutch cable
Last Post: 01rk
Wild One, Bugs (70), Blazer (67), OnDVirg (67), Buggyboy (64), TheChimp (49)
View Poll Results: Which type of oil do you use in your Sporty?
HD Dino Oil 236 16.62%
HD Synth 251 17.68%
non-HD Dino 227 15.99%
non-HD Synth 734 51.69%
Multiple Choice Poll. Voters: 1420. You may not vote on this poll
  #271
Old 26th November 2019
jkinkade jkinkade is offline
Sportster/Buell Model: XLH 88" 2003.
jkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant future
I'm at my happiest, feeling my sporty pull hard out of corners, she seems to throw me out of the corner. I can't go too hard down hill into a tight corner , unless the road is clear & I can keep it open & lean over. I got stock single disc 03 brakes. not complaining, just explaining.
Nibelungen's Avatar
Sportster/Buell Model: xl883n Iron (2019 engine)
Glad you enjoy your monster torque
IMO 2003 have strong brakes with hers 4 pistons calipers...
on wet and downhill without abs have to be careful though... uphill is a slightly different story... but could happens derapages and power slides
Nibelungen's Avatar
Originally Posted by Tomcatt View Post
Having nice weather to ride in is some consolation for having totally boring roads to ride on...
i understand your pain
last week was snowing on mountains... so i rode to the coast....
now my bike cruise well and fast even on highways... the sea was wonderful.... but the ride sadly was boring... all that long straight roads...
that is very true!! I have locked the front brake up on a twin cam dyna same brake but heavy bike.
I 'm not saying the roads here were I live are the best , but we have a great riding road we do once in a while from coast to mountains and inland. nearly all fine hot mix, so good dry weather traction. but some roads out west are a bit rough & they just dump cold mix bitumen over tar, nightmare for the belt!
well I have an Ozzy mineral base oil in my motor now. I'm going to try do a good long ride & use a heat gun get a reading from barrels. then drop oil change filter & fill with AMSOIL & do the same see if temp is lower.
Old 2nd January 2020
SLW210 SLW210 is offline
Sportster/Buell Model: 1
Sportster/Buell Year: 2
SLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond repute
We've found the Worlds' Fastest Stage 1 1200!!!
Only on the internet... I wonder what oil...
Sorry your bike is so pathetic. I got cash if you want to lose all of yours.
60Gunner's Avatar
60Gunner 60Gunner is offline
Hey, his oil is known to add 10hp when used with those hot cams he's running. Just though I'd warn you!
Old 3rd January 2020
Tomcatt Tomcatt is offline
Dazed & Confused
Other Motorcycle Year: 2015
So let's clarify this. You're claiming your stock gearing stage 1 1200C will pull 7,000 rpm in 5th gear? That's over 140 mph.
Long straight sections in 5th gear at 5,000 to 7,000RPM is far from boring to me.
I didn't know there were cliffs that tall in Florida.
Edit: We should probably start another thread so you can tell us all how you manage this miraculous feat!
Must have removed the 6000 rpm rev limiter.
glbsportster's Avatar
glbsportster glbsportster is offline
Sportster/Buell Model: 1200 C
glbsportster has a reputation beyond reputeglbsportster has a reputation beyond reputeglbsportster has a reputation beyond reputeglbsportster has a reputation beyond reputeglbsportster has a reputation beyond reputeglbsportster has a reputation beyond reputeglbsportster has a reputation beyond reputeglbsportster has a reputation beyond reputeglbsportster has a reputation beyond reputeglbsportster has a reputation beyond reputeglbsportster has a reputation beyond repute
Down here in Florida you can get alcohol free gasoline at every WaWa there is....not sure if that helps to get to those high RPMs, but it is good to know.....plus they have the best sandwiches there are.....if you come to Florida try a WaWa.
