0 hi all
Last Post: ironmanx
0 supply oil line seeping
Last Post: Scuba10jdl
Last Post: hexnut
0 New Member and a question
0 3.5" straight riser
Last Post: denguy
Last Post: MadMike_1126
0 Starter bushing/bearing install in primary cover
Last Post: 84cj
0 question for our machinists
  #791
Highly-Dangerous's Avatar
SPANIARD
Sportster/Buell Model: XL 883
Still on page #5...... work gets in the way.... Now I have a couple hours to keep reading... that Deutsche Plug / White wire ....
It is not Plug & Play?
Ok will sort this out later on...
A bit confused about starting a new thread.... I´ve got not a clue about mapping so maybe, no rush... (if you have some spare time).... you could enlighten me a little bit on what will I need to do and how much this "mapping" thing will cost me?
PM me if you like.
Cheers,
60Gunner's Avatar
60Gunner 60Gunner is offline
Chief of Security
You need to buy the cable and interface to load custom maps. If you have that, I could send you a map. Or George can. During breakin do as Hammer says.
That white wire needs to go from the #2 pin(I think brown/grey) in the plugin to the TC88A to an empty pin in the 4 pin data connection plug in down in front of the battery.
Check out this thread
rocketmangb's Avatar
The white wire is a tach lead and real time data feed to the USB interface.
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
SPANIARD
Thanks guys... I think I understand it now.
I´ve ordered, also from Hammer, the Programming Kit for the TC88A... so I guess that will be all I need?
